    Veteran Member Three Rings braker15's Avatar
    Nov 14 2008
    2000 S4 Nogaro Blue
    S.Florida
    Hubcentric Rings, ok to run??
    iam trying to get some wheels, but they have hub centric rings 57.1,
    would it be aight to run them? do the rings make noise or vibrate??
    tk
    2000 S4//GIAC Tune//AWE Intake//AWE DTS Bar//Cross,Drilled Rotors//18" RS4's AtItalia//Bridgestone//Pioneer Navi//more to come
    Gone: B6-APR stage II+/K04-015/ER sport fmic/Genesis 380cc/Forge 007/Magnaflow 16601/R8 reps/Prosport gauge/Koni Coilovers/K&N/badged
    Veteran Member Three Rings Cadiburns's Avatar
    Feb 17 2010
    Chicago
    The whole point of hubcentric rings is that they center the wheel and the hub so that the wheel doesn't vibrate....
    B5 Casa S4 Avant | Tial 605s | EPL | Aquamist
    Account Terminated Four Rings
    Oct 26 2009
    Beaver Creek, CO
    57.1 is the hub size for Audis. If the wheel is bigger than that than you need the rings to prevent vibration from an improperly seated wheel.
    Established Member Two Rings Thizz_S4's Avatar
    May 25 2010
    B5 S4 Avant, 04 SVT Focus, 13 Explorer Sport, 07 6.0L F350
    SACRAMENTO, CA WEST COASTIN'
    hubcentric rings will almost eliminate all vibrations caused by a wheel that has a oversized hub hole. S4 hub = 57.1mm
    Veteran Member Three Rings arotished's Avatar
    Jul 04 2010
    Norway
    newer use 66.6 (or 66.1)
