Results 1 to 4 of 4
Thread: Tires are done!
    Jul 29 2009
    NH USA
    Tires are done!
    So my stock tires are terrible. They sound like swampers on a F350 when I am on the highway. The tire place I am going to is trying to charge me 40 dollars for recalibrating my tire sensors. Now I know that is BS. I can just reset that through the computer. I should tell them to blow on that right?
    -Josh
    2010 Audi A4 2.0T Quattro
    Established Member Two Rings droppyale's Avatar
    Aug 05 2010
    San Francisco, CA
    What tires are those? Pierlli? Also how many miles on them?
    2011 A4 2.0T Quattro Prestige Sedan w/Nav
    KWV2 - 5mm/10mm Spacers - Chrome Inserts - VAG-COM
    Mar 02 2007
    Fresno, CA
    Yes, resetting the TPMS is something you can do on your own. Check the manual for the exact procedure.
    Veteran Member Three Rings NickZag's Avatar
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    $40 to reset the TPMS... what a scam. I wouldn't even shop at a place that charges for something like that. All you need to do after you get your new tires installed (with proper PSI) is go into the MMI and reset it. It literally takes less then a minute.
