Originally Posted by
bigblue
Lol, get that pig to turn man. You gotta turn the crank, you can't get at it from below somehow? Fyi you got a hottie there. Now wheres a pic of said car?
Haha she is pretty hot, if only you could see her like I get to
I need to take updated photos, the emblem is chrome and it looks a ton better
And good thing I decided to order a new snub mount, this is bad lol
guy022077
well you could put it in gear 5th or reverse and try and turn the wheels, if you only have to move it a little, it just might work. are you using a 5mm allen or a 10mm socket? an allen should not require that much clearance
I can't turn the wheels because the car is jacked up in the front or can I turn the fronts only? I have an extended ball point allen, it barely made it for the other bolt, I had to turn it with a monkey wrench, this one can't even touch the bolt because of the subframe. I'm about to just cut the bit until it fits I'm tired of this bullshit. At least I'm getting a lot of good things done in the process, snub mount, cam tensioner gasket (which I hope isn't another bitch of a job) and a lot of good cleaning under there.
