    Oct 27 2010
    Valley Cottage NY
    ipod connector inside glove compartment
    how do i get my ipod touch to work with my car it doesnt connect to any ipods even friends some one please help
    Veteran Member Four Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    bad start man. slow down and use punctuation. offer as many details about your problem as you can. maybe someone can help.
    I have ipod dock in my my car and it works. I may be able to advise, but i can't tell what your issue is.
    If you've got the ipod doc in there and you KNOW that you've fully docked the ipod to it, then clearly there's a problem somewhere along the way. I'd guess that the doc you isn't hooked up to the stero. But note that it's a bitch to connect the thing because the docking pins are way back in there. It's truly a stupid design.
    Here's a Q. When you've got the ipod docked in there, does the screen light up or anything happen to the iPod. The screen should light up and you'd see the red crossed out circle. This indicates it's connected and synching to the radio. if you don't get this, then the ipod either isn't truly connected, of you got screwed and the doc isn't connected to the radio.
    That's my guess.
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
    Oct 27 2010
    Valley Cottage NY
    thanks.... ill try what you said.
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    And hit the CD button twice so that the display says CDC6
    Jul 26 2010
    Atlanta, GA
    Quote Originally Posted by chrislane31 View Post
    Oh yes, good point. If you get to the stage where the ipod is connected and the screen lights up, you know it's connected properly.
    Then, press the CD button. I've got Symph II+ that has 6 CD changer. If press CD once, you'll see CD 1-6, representing the disks you've got in there. Press CD AGAIN, and display will show CD 7-12.
    Ready for this.... CD 7-11 represents the first 5 playlists you have on your ipod. CD 12 represents your entire ipod.
    And if you get it all working, you might as well prepare for the fact that you see nothing from your ipod. no playlist names, no song names, no nothing. And for me, if i play CD7 (representing playlist 1), or CD 12 (represnting entire ipod) it starts with a random song. I can't figure it out. It's not the first song alphabetically or the first artist alphbetically, it's just some song.
    I press MIX, secled "CD" and the MIX again, and then it just shuffles all songs.
