    Veteran Member Three Rings mattg1.8's Avatar
    Sep 16 2009
    San Diego
    Joey Mod question
    Ive done the joey mod once before but im helping a friend do another one soon and i was thinking about just letting the headlights bake in the oven at like 250 degrees for a couple of minutes and then trying to pull them apart instead of heating and prying the lens off has anyone used another attempt like this to get the lens off?
    Jun 25 2008
    Cleveland
    I just did mine last weekend and used a heat gun and pryed the lens off. Mine had ALOT of silicon/sealant so I'm not sure how easily you will be able to "pull them apart". Good luck.
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    Ugh I wish I could have someone do this for me that has done it before SUCCESSFULLY (that includes no leaking after they are put back together!) Too scared to do it :)
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    225 for 8 min at a time worked easy for me, just remember the amount of pressure to use and itll be a breeze.
    if you double or triple seal the channel after closing them back up, you will not get any leaking issues.
    Sep 16 2009
    San Diego
    Quote Originally Posted by Kwarner View Post
    Did that still require you to pry the whole lip up or did you just have to do it in certain spots to get a prying point?
