We are offering a special introductory Group Buy price on our new rear adjustable sway bar end links.
OPTION 1 (Aftermarket Bar in "Aggressive" Setting) : Only $150 shipped, per pair
OPTION 2 (Stock Bar or Aftermarket Bar in "Neutral" Setting) : Only $160 shipped, per pair
Full length adjustable sway bar end links for the rear of B5 (and B4) chassis sway bars. Will also work on any other sway bar application that uses a link in the 6-8" long range, featuring 10mm hardware at each rod end. Fully rebuildable.
Allows for several advantages/features:
* Remove any preload from sway bar for more even handling, especially when corner balancing
* Dramatically improve sway bar response and reaction time
* Billet aluminum construction for unmatched strength compared to weak stock plastic and thin steel units
* Black anodized aluminum body with plated rod ends for rust and corrosion resistance.
* Motorsport quality Aurora rod ends are teflon lined for long life, strength and performance, with 1/2" shank for the ultimate strength.
* Includes jam nuts and all new hardware needed, easy to install and adjust.
* Completely rebuildable; the last set of links you'll ever need to buy
* Hang around your neck to attract the honeys when out at the club.
There are now 2 options to take care of anyone and everyone. Please chose "Option 1" for aftermarket sway bars used in the "aggressive position". Please chose "Option 2" for those who are running a stock swaybar or an aftermarket sway bar in the "neutral position". .
Retail on these is $195, so get on this while you can!
PM me the following info:
- Name
- Email address
- Shipping address
- Vehicle (there aren't different models but I'd like to know who is ordering these)
- Option 1 or Option 2
We will email you an invoice for the discounted price so you can make payment via our website or phone.
*$150 shipped offer applies to lower 48 states only*
