we have a 165,xxx on the car, and the pass front wheel always seems to have way more brake dust on it than any other wheel, on top of that, i've noticed if i take my hads off the wheel the car has a pretty hard pull to the right. That makes me think possibly i've got a sticky rotor, however, i've also got some clunking / rattling in the front susp when going over bumps, and i'm guessing that's probably some worn out control arm bushings and tie rod ends, which i've read can also cause a pull. Back to the brakes, the rears pads are pretty worn, the front pads are in great shape but the rotors apear to be rather old because they have very small little grooves in them, not grooves from a caliper or worn out pad, but similar grooves to my old worn out 01 S4 stock rotors at 50K miles. Due to the cars age/mileage i don't care to spend a lot of $$$ upgrading the brakes cause it's simply a dd commuter car the jeeps are our toys What is a good route to go, i want to replace rotors all the way around, new calipers up front and new pads in the rear....should i look in the classifieds here for some used S4 brakes from a B7 or just buy aftermarket stock replacement parts.....also is there any thing special i need to know about changing the brakes other than getting the tool to twist the rear caliper piston back in
