Results 1 to 7 of 7
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    Updated: Anyone have issues with leaking headliner? Possible sunroof issue?
    Went to put my son in his car seat and noticed that the seat belt (which was retracted) was completely soaked. After looking around I noticed the water was dripping from the corner of the healiner (rear coner, driver side). I'm assuming this is the clogged sunroof issue. Then I noticed the rear section of the headliner was stained. Made an appointment with the dealer, but they can only take me next week. Anyway, any ideas if the dealer will replace the headliner? Shouldn't they, if it was caused by the sunroof issue? Anyone have this same thing happen before?
    UPDATE: Dropped car off exactly 3 weeks ago. Rear sunroof drains were clogged. Dealer fixed it under warranty. However, they did not replace my headliner. They told me it was not covered under warranty. I showed them the stains that resulted from the water sitting on the liner, and asked if they could at least clean it. According to them, the detailing department could not remove the stains.
    Eventually, the service rep took pictures and sent them to the regional Audi rep. 2 weeks go by and no word from the rep. So I called Audi Customer Relations and they followed up. Today I got a call from the service rep telling me that Audi gave them the go ahead to replace the head liner. It took a while and some complaining, but they came through.
    2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    There is a pending corporate litigation on this issue. I remember getting some documentation in the mail regarding the suit, but unaware if Audi conceded to it yet.
    Here's a thread about it: http://www.audizine.com/forum/showth...ss-action-suit
    Mar 30 2009
    Yeah, I got that notice too a while back. For some reason I put it in my head that the clog would cause the leak to appear towards the front for some reason. Not really a logical reason. I'm pretty sure though that the clogged sunroof issue is what is causing it. Just hoping that they will replace my headliner as well.
    Jul 27 2009
    '15 S3
    Boston
    I suspect if they confirm that the sunroof was in fact at fault, then they would have to replace any corresponding damaged parts.
    Good luck, and update the thread after you take it in to the dealer.
    Mar 30 2009
    Update. See top of thread.
    Veteran Member Four Rings Korrect414's Avatar
    Northern CA
    I'm glad they are going to replace your headliner. They should've just done it anyways.
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by vwnobby View Post
    Nice to hear. Great job working your way up ladder until someone made it happen.
