Thread: Axle problem!!!
    Veteran Member Three Rings s4killer's Avatar
    Jul 27 2009
    audi s4 b5(sold( corolla 95 stick, jetta se, honda civic ex
    wisconsin
    Axle problem!!!
    hey friends I have a small problem
    left front outer cv boot torn
    and
    right front drive axle seal
    it is better to replace them, or change the whole axle ......
    this question is silly but the new axle has included the axle seal?
    the cost of this is 4.5 hours $ 360 IS OK?????? JUST FOR CV BOOT AND AXLE SEAL
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Veteran Member Four Rings Street Nasty's Avatar
    Jan 20 2009
    B5 S4 Avant
    How many miles do you have on the axle? If it's old, I would just replace it with one from raxles. Labor is going to be the same for both jobs. 4.5 hours is a long time. It should take only about 1.5 for the job. Is this the dealer?
    Jul 27 2009
    wisconsin
    Quote Originally Posted by Street Nasty View Post
    is my stock axle with 91k is a small car company just sell euro cars so for this jod i can go with on any shop?
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Jan 20 2009
    B5 S4 Avant
    Replace that sucker and ask in your regional forum for shop recommendations. Hopefully someone can help you find a good shop around your way. I think the labor money is up there because of them also charging for the cleaning, etc.
    Dec 06 2007
    Calgary, AB, Canada
    Replacing the whole axle takes less time and labor than doing the CV boot.
    The reason that the labor estimate is so high is because they're replacing the driver's side output flange seal, in addition to the passenger side axle. They have to remove both axles in the process. I think it should be maybe 3 hours for the job.
