Results 1 to 30 of 30
Thread: turbo questions
    Jul 18 2010
    Fayetteville/ NC
    turbo questions
    should I get the oem revision diverter valve (electronic) or a hyperboost (vacum) Pros and Cons.... And other thoughts
    Veteran Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    the hyperboost? thats a new 1 to me...
    OEM one is the best 1 and its alot cheaper than the forge dv and works just as well. Go oem all the way just get the newest revision.
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    I could of fucking sworn there is blazes of threads on shit like this.
    Jul 18 2010
    Fayetteville/ NC
    yep there is, didnt find exactly what i wanted to hear tho
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by makav3li View Post
    Me neither. First time I've heard someone mention a hyperboost.
    Boone, as stated above, just go OEM.
    Veteran Member Three Rings schizzy's Avatar
    Jun 29 2009
    2008 SRT4
    New Jersey
    never heard of it either... have the forge dv, best money Ive spent on the car yet. no more rubber diaphragm
    Ocean Blue b7 a4: -Revo stage II -apr/BB exhaust w/ tp -eibach/kw coil overs -19" sportec mono 10 -forge dv -rs4 swaybar -rs style grill -euro jet pcv fix -apr snub mount -custom intake -m3 spoiler -35% tints...... TOTALED BY DUMP TRUCK
    Current: 1990 vw
    Jul 18 2010
    Fayetteville/ NC
    http://www.millteksport.com/hyperboost.cfm
    NOW YALL HEARD OF IT haha
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    Quote Originally Posted by BOONEAUDI View Post
    Really? Two threads in the last two days I clearly stated that the person just go with the OEM piston revision DV. Others too. Others also said Forge. You have to make your mind up
    Now three.
    Oh wait, it was YOUR thread the other day I said go OEM. Seriously? You didn't need another damn thread. You now have 3/3 failed threads. You even created a blog on this site about it. Jebus man.
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Veteran Member Four Rings VegasAIV's Avatar
    Feb 25 2009
    B7 A4
    Las Vegas
    Quote Originally Posted by eskimopunk View Post
    Reall? Two threads in the last two days I clearly stated that the person just go with the OEM piston revision DV. Others too. Others also said Forge. You have to make your mind up
    Now three.
    el oh el
    F.T.W.L.T.B.D.W.I.C.T.W
    Turbo lag is just foreplay...
    Senior Member Three Rings AudiFan6482's Avatar
    Mar 19 2009
    2005 Chrysler Pacifica, 1972 Mercedes Benz 300
    Colorado
    Maybe the B7 guys havent heard of the Hyperboost because it does not fit our vehicles...
    2008 A4 6MT Quattro... Monster mats...APR STG2...TP
    Established Member Two Rings BladesBravo's Avatar
    Aug 25 2009
    Are there any variable-flow turbos for the 2.0L B7? While Phil is LEDing my lights I have been driving my Dad's Acura RDX and holy crap is the turbo so much better then our stock one. 0 lag time and even though its an SUV only having a engine 0.3L bigger gives it faster 0-60.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I had hyperboost on my jetta, but I don't think it fits or cars
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings Sprode's Avatar
    Aug 27 2009
    07 S-Line, 97 Supra Turbo
    Arlington, VA
    Performance: OEM. Piston valve.
    Sound it makes: Forge.
    Stop making threads.
    Established Member Two Rings Baruch's Avatar
    Jun 28 2010
    08 A4 Qt 6 Sp MT, 06 GSXR 600
    LI - NY
    Anything comprable to this for our Audis? Id be all over it like white on rice....
    08 A4 Quattro - 6sp MT
    APR Stg II+ - Carbonio Intake, HPFP Rebuild, Testpipe, APR Catback
    RS4 Rear Sway
    Debadged/35% Tint
    Aug 27 2009
    Arlington, VA
    Quote Originally Posted by BladesBravo View Post
    Since this is the only legitimate question in this thread.
    No. Not yet. The only turbo that BW manufactures for gas powered cars with VTG is on the 997. Nothing with ball bearings either ... You all want to hear your turbo more, that is what you need.
    You will have better luck searching for variable turbine geometry if you want to know more about it. I hadn't heard it called variable flow turbo, and Acura's description is misleading
    To reduce turbo lag and boost engine response, the variable flow turbocharger narrows its intake duct at low rpm, increasing the speed of airflow, which keeps the turbine spinning quickly at low rpm.
    But what they mean is the exhaust intake duct. I had to read the patent to understand that they weren't trying to say there was an advantage in closing off the intake duct.
    So the search turned this up, but its not honda's http://www.patentstorm.us/applicatio...090151350.html but even this is just more VTG.
    Established Member Three Rings mo17k3y85's Avatar
    Oct 23 2010
    B7 A4, lexus RX330, F150 Roush
    carbondale il
    U guys should go easy on us newbies, how is the community going to grow with people being so hostile. Damn it
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Stick with the OEM DV, part number is 06H 145 710 D. This one's actually the latest one used in the newer 2.0T and it works fine with ours. Unlike the old DV, there's no diaphragm so it won't rip especially if you chip your car.
    Mike
    Aug 27 2009
    Arlington, VA
    Quote Originally Posted by mo17k3y85 View Post
    This guy isn't happy until people tell him what he wants to hear. He made a thread yesterday asking the same question, then instead of just continuing the thread with the answers in it, he makes another one. He deserves it.
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by AudiFan6482 View Post
    Pretty sure you're right. I think it's designed for B6 and previous models.
    Quote Originally Posted by Sprode View Post
    True dat. That is the exact reason for everyone's hostility.
    Senior Member Two Rings STONER's Avatar
    Sep 02 2009
    B7 A4, B8.5 S4, A3 Tdi
    Layton/Utah
    As the great Duke Nukem would say- BLOW IT OUT YOUR ASS!!!!!
    No need for hostility this isnt a Honda forum.
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    Quote Originally Posted by STONER View Post
    Hey, people are going to get annoyed when the same questions are asked over and over and over when a search would provide the answers. Waste. Of. Time.
    2005 B7 A4 2.0T | Brilliant Red | 6MT
    Veteran Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2008 VW Jetta Wolfsburg 2.0T 6DSG
    Staten Island, NY
    classic repeat thread lol
    Veteran Member Four Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    Quote Originally Posted by billyhoyle View Post
    For real. I'm all about being polite and helping the noobs - I'm pretty much still one myself - but come one. Two different posts on the same subject in two days ...on a topic that can easily be searched. That's just disrespectful of the forum's time and taking the forum for granted. Do some of your own work, and if you're truly stumped, then ask for help.
    And mutherfeking take or don't take the advise you asked for - but don't just ask the same question again the next day. ... or if you do, expect to get flammed.
    I'd better stop now, or I'll warrant a "Oh, He Mad!" picture from someone.
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
    Dec 18 2009
    Pennsylvania
    You fucking fail. If you even skimmed through that website you would see that its not listed that it fits our cars. Stop making useless threads.
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by GA42.0T View Post
    Might as well throw it in here...
    Jul 26 2010
    Atlanta, GA
    Thanks beantown. Morgan is my fav of all those.
    Jun 28 2010
    LI - NY
    How about instead of complaining that its a similar post just hit that back button on your browser... Guy has a question and starts a thread, either don't look or help the guy by re-directing him to the original post... you're not changing anything by insults or saying its already been done... Nor am I changing anything, I just have some time to kill before I get off work so yayyy...
    RS4 Rear Sway
    Debadged/35% Tint
    Mar 26 2008
    Las Vegas
    Quote Originally Posted by Baruch View Post
    You mean re-directing him from this thread to his original thread?
    Well next time, he will most likely think twice before starting a new thread. Maybe he'll even use the search button. This would not have happened without the insults.
    You've only been on here a couple months. Don't try and tell us (the ones that are on here everyday) how to go about posting. If we ignored this thread, he would just make another one. Your logic fails.
    flickr
    SBSC Designer
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    X2
    /thread
    RIP QG TI B7 A4
    Jun 28 2010
    LI - NY
    My mistake.. I did mean thread*** well, I feel your logic is questionable sir. You paste the re-direct link and thread is dead - goes away with all the other countless and pointless threads, couple probably started by me ;-p ... By insulting the guy youre just re-fueling and re-activating the thread. Now a thread that could have just had 3 posts has 30 posts because other people chimed in to post pictures or insults
    Personally, i don't really care and i feel its somewhat entertaining but - im bored at work and i normally come on here and look around a couple times a day... Also, i don't really see how its relevant that ive only been here a couple months...
    Obviously im not trying to change anything cause its useless, its the internet.. but what im trying to say is that youre changing nothing either, why insult someone when you can help em out? Just my $0.02.. Have a great day!
    RS4 Rear Sway
    Debadged/35% Tint
