Results 1 to 6 of 6
    Veteran Member Three Rings noznab's Avatar
    Jul 08 2007
    Tri-State
    Has anyone ever replaced the motor that locks our gas cap door?
    I noticed a while ago the pin that locks the door to the gas cap in my car is missing Has anyone ever had to replace this? I'm guessing I'll start by ripping out the trunk liner to take a closer look at what's involved. Can anyone get me a part number for the assembly I'd need?
    A few mods here and there
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    You don't have to take the liner completely out but it helps to pull the side away as much as possible. The pin is attached to a white actuator that slides in place. Usually they are in there tight and I tap it forward with a long screwdriver and hammer then pull out.
    When you get the new one try to tighten the screws to the same point as the old one and then good luck getting the pin in the hole. Once you have the pin in the hole push the actuator on and pull it back into place, done.
    The hardest part is getting the new pin in the hole and that is what "she" is for.
    Senior Member Three Rings ozo101's Avatar
    Jan 24 2009
    nj
    I have it, make an offer if need it
    Drop den Vorschlaghammer!
    Jul 08 2007
    Tri-State
    Sent you a PM ozo
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    Ive never had to replace mine but jimmy put it best.. If you do end up chantging it maybe posting some pics to help others
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Jul 08 2007
    Tri-State
    I definitely will when I get around to doing it. I've been meaning to post a diy on how to fix a broken home link too-- For those who are wondering, when your control arms go bad they have so much play that they tear the wires in your wheel well that send power to the buttons on your visor.
