Results 1 to 8 of 8
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2011 Q7 TDI Prestige, '72 Nova
    The Cheese State
    4.2 6 Speed vs. 1.8T 6 Speed Differences
    I've searched and come up empty-handed. A few questions:
    -Do the 4.2 and 1.8T 6 speed manual transmission share bellhousing bolt pattern? i.e. can I bolt a 4.2 6 speed up to my 1.8T
    -What are the differences in the gear ratios between the 4.2 and 1.8T 6 speed?
    TIA.
    '11 Q7 TDI Prestige
    Function > Form
    Dec 03 2005
    2 pedals 1FG
    connecticut
    -Doug
    Oct 27 2009
    The Cheese State
    Thanks Doug!
    '11 Q7 TDI Prestige
    Function > Form
    Oct 27 2009
    The Cheese State
    Anyone have input on the bolt pattern?
    What about the rear diff? Any difference between A4 and S4?
    '11 Q7 TDI Prestige
    Function > Form
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by drjonez View Post
    different gear ratios as well i would assume
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Oct 27 2009
    The Cheese State
    Quote Originally Posted by onceover View Post
    I would think so too...but based on Doug's link both the 4.2 and the 1.8T have a 3.89 final drive....indicating the same diff.
    '11 Q7 TDI Prestige
    Function > Form
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    Bolt pattern is the same, and as long as the rear diff final drive matches the transaxle final drive you should be golden.
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Oct 27 2009
    The Cheese State
    Good info, thanks!
    '11 Q7 TDI Prestige
    Function > Form
