would any of this contribute to getting 13 mpg?
2000 s4 6 speed stg 2 + 114k ( perfect psi in tires :) )
giac chip 16 psi
manual boost controller
SSAC full exhaust ( downpipes, test pipes)
leaky valve cover gasket / cam seals ( replacing this weekend )
CEL codes =
both post cat o2's not hooked up, throwing CEL.
n75 and n249 delete, both throwing CEL.
was going to get a custom tune and CODE those 4 codes out of the system in the spring when I got stg 3.....
Now my question is, before I get it custom tuned and coded out, are those CEL's giving me this horrible MPG? so will the problem go away when I get them deleted?
if not , then where the hell do I start? ( spark plugs?, gaskets? tune?)
thank you so much in advance. Just curious on if the answer if right in front of me cause of my current issues.
=D
