Results 1 to 3 of 3
Thread: coil gasket?
    Senior Member Three Rings Just_dizzle's Avatar
    May 16 2010
    jeep cj7 on 35's (for sale). toyota fj62, 71 bmw2002
    ABQ
    coil gasket?
    Have you guys ever seen a coil gasket rip or tear? So my PS head first coil looks like the gasket is ripped, ever experience this?
    Car starts fine, idles fine, when i give i gas it just doesn't really wanna move.(but will drive slow and hesitant) I see some oil leaking from that coil as well.
    So buying all new coils is there a brand thats better then the rest? Anything else i should do while im replacing these?
    Thank you
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Pictures?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    May 16 2010
    ABQ
    Quote Originally Posted by RolledMySTi View Post
    Pictures?
    Ill try and take some tomorrow. Back at work now
