Not sure if this issue is common. On my front passenger headlight, sometimes it works but most often it doesn't. I changed the bulb and the problem persists. I noticed if I tap the headlight with my fist it'll go on but then it might turn off again. I've even cleaned the contact points between the bulb and the light assembly. It's driving me nuts looking at the change bulb sign on my dash. Now the left turn signal is doing the same. Is it a wiring problem? Can't be the fuse. Help. My headlight assembly is factory.
Danke.
