Results 1 to 7 of 7
Thread: Injectors
    Senior Member Three Rings SoFarGon's Avatar
    Jun 01 2010
    North East
    Injectors
    I have a set of Porsche orange top
    injectors... I think they're 400's... Question... With a carbonio/apr testpipe/inlet hose/stage 2 programming are there any other mods to be done before puttin them in? Thanks...
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Yes, A Big Turbo.. And unless they are for FSI engines you will not be able to use those...
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    For some reason I HIGHLY doubt those will work. Feel free to prove me wrong though.
    B7 A4.... 394awhp
    Jun 01 2010
    North East
    They are the injecors that are used by apr... They don't say who makes them but we ran the serial numbers from them, turns out they're Porsche cayennes... Anywho, is it true big turbo is needed? Aren't some stage 2's injectors??
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    I would definitely get an upgraded FP before thinking about messing with injectors. Oh yeah and while you have it off check the follower and camlobe. Since adding more load on the pump with upgraded injectors may not be the best choice if those two pieces have been compromised.
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    1) You would definitely need a tune
    2) More than likely a different HPFP. Just quickly comparing the 2 models fuel system's, it looks like you would need a lot of things (rails, LPFP, pressure regulator, etc) but that is by no means definitive.
    Btw, with our tiny little OEM snail, the fuel injectors aren't going to do anything for performance.
    Senior Member Three Rings deeznuts's Avatar
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    I think your going to fuck something up if you just throw bigger injectors into the car....regardless if theyre the right ones or not, you need a tune for injectors...otherwise your going to be running rich and your just fucking things up in thr long run....be patient.dont half ass things youre going to end up paying for your stupidity down the line.
    Koni ss, creative test pipe/downpipe, britalman exhaust, greddy fmic, rs4 sways, apr stg II, a lot of adrenaline
