Results 1 to 14 of 14
    Apr 15 2009
    PA
    B7A4 brake upgrade ** what about buying reman calipers?
    I've been searching through the archives on B7A4 upgrades for my B6USP and getting good info. But, is there some obvious reason that I am missing why I don't seem to see any recommendations just to run to NAPA and buy reman calipers for, say, a 2008 Audi A4? They are 100$ and, at least on the website, have the Audi rings stamped on them making me think they'd be a nice refreshed OEM caliper source. Maybe it is because you also need to source the carriers and it is easier to get everything as one package? It doesn't seem used calipers from the classified are being sold for much less than this (in fact, I've seen $150 each referred to as a "good price").
    2019 Audi RS5.
    Jan 10 2007
    VA
    The remanufactured calipers likely doesn't include:
    Carriers: about $150 each new.
    Guide Pins: (2 needed per carrier) about $12 each new.
    Springs: $22 each new
    So that alone would be about $400 in parts you'd have to buy to install those remanufactured calipers...not including the rotors and pads.
    That's why $300 is a good price for a complete set of B7 A4 calipers (carriers/pins/springs included) in the classifieds.
    Apr 15 2009
    PA
    Quote Originally Posted by b6onboost View Post
    Ah, thanks for the clarification. I knew there was an obvious reason. I didn't realize the carriers were so expensive.
    2019 Audi RS5.
    May 27 2007
    New York
    Ask them how much they charge for "Loaded calipers" those include pads springs and pins typically
    Veteran Member Four Rings nofearhawk's Avatar
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    Yea carriers are always damn expensive. If you have access to a CNC machine you could always make your own.
    Oct 16 2006
    Naperville
    you also dont have the hard brake line and the bracket that holds it. thats another 40 bucks new each side.
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    Noob question....wtf are carriers? I always see stuff about them but I have no idea what they are
    Active Member One Ring Shark-357's Avatar
    May 16 2010
    Audi A4 B6 1.8T
    Slovenia/Europe
    So all B6 stock front brakes are 288mm, and all b7 stock front brakes are 312mm? Am i right ? if thats so i could be looking into some cheap brak upgrade i can get complete front brake of an 1.9tdi b7 2006 for 150€ (callipers,carriers, guide pin and springs. Would i also need the back dust shield or what is it called in english??)
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    Don't forget when you buy those remaned calipers you most of the time need to return them the same calipers for a core charge.
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    Quote Originally Posted by CoreyRS View Post
    Carriers are the part of the brake that gets attached to the car. The part that the two bolts go into that secure the caliper to the car. The caliper gets attached to the carrier and has the piston in it.
    Oct 16 2006
    Naperville
    Quote Originally Posted by Shark-357 View Post
    b7 a4 calipers are 320mm .
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    B6 1.8T are 288mm
    B6 3.0L are 312mm
    B7 2.0T/3.2L are 321mm
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Reman calipers always come with the spring kit, and new pins. At least every one that I sell at advance auto does. And you can put whatever caliper you want in the box, how will anyone know until it gets to the reman company?
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Mar 27 2009
    Columbus, Ohio
    Quote Originally Posted by bigblue View Post
    Karma is a bitch. That is just like saying they can put any caliper they want in the box you pay for. How pissed would you be if that happened to you.
    I think we have proved the point that it is still cheaper to just buy used here and go from there.
