Results 1 to 4 of 4
    Veteran Member Four Rings promoda's Avatar
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    Chrome mirror housing?
    Hey Guys I just bout a pair of the S4 mirror housings... would anybody be able to give me an idea on the level of difficulty to install them? do I need to take the whole mirror off?
    thank you!
    Promoda
    Veteran Member Three Rings BLopes07's Avatar
    Nov 08 2009
    North Jersey
    It's not that difficult but you do have to be very careful you could crack your mirror or break a few clips on the housing. I remember the first time I did it I cracked my mirror. Just remember to move the mirror into the car so u can fit ur fingers behind it and pop it out. But I recommend having a buddy who's done it before but if your careful I'm sure you can do it man
    [Audi 2006 A4 2.0T]-Revo Stage 2-custom borla exhaust-034 Silicon Turbo Inlet Hose-034 Test Pipe-Oem Piston Diverter-Carbonio-VMR Boost Gauge-v8 coils
    -Full S.Line Conversion-S4 Door Blades-Deval Lip-Oem Titanium Rims--H&R Coils-Titanium Grille-ECS Drilled and Slotted Rotars
    Mar 05 2009
    Earth
    I've done it a few times when I had my carbon mirrors made.
    Point the mirror all the way in using the motor (or pushing)....grab a towel around the outside edge and pull forward on the one side until it's out of the clip and then pull the other side out.....don't jerk it out but use a steady firm action. I'm not sure what year you have (or if the procedure is different after they changed styles from '09) but the mirror housing itself slides off after depressing clips...no screws need to be touched. It's on there pretty tight but once it lets go it comes right off. Putting it back on was more difficult for me.
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    Thanks guys I think i might have a bodyshop do it, i was just curious how difficult and long it takes to do... thanks guys
