Results 1 to 4 of 4
    Apr 23 2010
    Sweden
    19x9 et33 will it fit or will it scrape?
    Hey guys!
    Been searching everywhere but haven't really found a answer to my question.
    Ive been thinking about purchasing Audi bbs speedline(rs861) and they are 19x9 et33 and i am probably gonna run 245 tires on them. so the question is will they fit on my audi a4 b7 without rubbing/scrape to much?
    I will also probably lower it with h&r 45mm springs in the near future.
    Thankful for help
    Veteran Member Three Rings porkchops!'s Avatar
    Jun 18 2008
    b7 s-line a4 2.0t quattro 6mt
    canton/new haven CT
    They'll be fine, just space the rears 5mm at least. And definitely LOWER IT FIRST. Please. And if you are planning on being low low, get 235/35's or even 225/35's all around (my personal preference)... but that is only if you go low enough to pull it off.
    If there were two guys named Hambone and Flippy, which one would you think liked dolphins more? I bet you'd say Flippy, wouldn't you?
    But you would be wrong. It's Hambone.
    FTWLTBDWICTW - don't tell your mother
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    i run 19x9 et 29 with 225/35 and no problems.. and i'm really low.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Do not go with 245s, I have 243/35 on my 19x8.5 et35 and they rub quite a bit
    2021 Audi S4, P34 Intake
