Results 1 to 8 of 8
Thread: ESP light
    May 25 2008
    jerz
    ESP light
    was driving today on the highway and everytime there's a little turn in the highway at around 60MPH the ESP comes on and feels like it won't let me accelerate
    it did this around any turn and just started today... any ideas on what could be wrong? thanx
    Senior Member Two Rings chayden's Avatar
    Jul 15 2010
    1984 Porsche Carrera 3.2, 2004 Porsche Cayenne s, 1997 VW Jetta VR6
    Fairfax VA
    hows your tire tread, what was the temperature out side, what type of tires do u have, was there gravel on the road, all of thos have factors on how much traction you have. im not saying thats your problem but it could play a factor, im not the best electrical guy so some one else can chime in.
    Oct 16 2006
    Naperville
    better than my problem, anytime i drive over 30 mins, my esp light comes on (which means esp is disabled) im unsure whats the problem.
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    Quote Originally Posted by manguyen View Post
    I always disable it when it rains or snows anyway... which is like 50% of the year at least lol
    -Eric
    R 1 3 5
    2 4 6
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    If you do a search here, you'll find the main reasons for the esp light coming on are a bad brake light switch/sensor (especially on the TIP cars-mine did this) the MAF, or trouble with the ABS. A low battery can also trigger that warning light, and so can very worn brake pads.
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    When you don't have a lot of traction the esp light will come on and it will try to keep the car in control... thus you won't be able to accelerate anymore than your current speed until the car detects that it has enough traction back... thats the point of the system... Thats why you have to shut it off to do a burn out... not that I can since I'm auto but on other cars vag products thats what I've had to do.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Aug 26 2005
    Quote Originally Posted by Scrwedtxboy31 View Post
    Why?
    Vorsprung durch Technik
    Sep 22 2010
    Sask, SK
    When you hard accelerate (or light accelerate depending on how bad the road is) and the tires start to slip, the ESP light should do a quick flash (on,off,on,off rapidly) basically confirming tracktion is minimal and tires are slipping.
    Today was the first time it snowed here and when I would stomp on it this would happen. When i lay off and allow the tires to catch the light is off as per normal, it resumes to flashing once tracktion starts to slip again.
