Results 1 to 25 of 25
    Oct 21 2005
    y
    Remove speed limiter AEB for FREE!
    Just cut wire #20 (white/blue) in the ECU harness. No more speed LIMITER!
    *****This will give you a Check Engine Light.*****
    Your speedometer will still work. Tried and tested in my car (AEB). But will most likely work in any other car.
    *I use an AEM FIC to tune my car. So chipping the ECU just to remove the speed-limiter isn't a cost-effective option.
    EDIT: Added bonus! Lost my rev-limiter. Good thing I can set a rev-limit using FIC.
    EDIT 2: It only removed the rev-limiter on one of my ECU's. It either removed the limiter or the other ECU (stock) is messed up.
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    huh good to know.. But out here in cali if you have a check engine you aint passin smog......... I heard there is a way to do it through vag com... Any body know??
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    who still hasnt chipped their car? lol
    Sep 12 2008
    South Central PA
    I have an APEXi SAFC, if you want it. lol.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Three Rings Castor Troy's Avatar
    Dec 17 2008
    Billings, MT
    lol like a stock b5a4 can hit the speed limiter anyway?
    May 07 2007
    Hey, with 20 miles of downhill, straight road; ANYTHING is possible.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by Castor Troy View Post
    rofl.
    I don't think it's possible. when my car was stock I tried it.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    I did it going downhill.. on a portion of the thruway coming from Boston. Non chipped a4.. ran right up to redline.. took me a few minutes.. However the car felt very solid at that speed. I wount do that again with out a big brake kit better suspension/ sway bars and probably a better set of tires.. And oh yea hit the speed limiter on a track!
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Veteran Member Three Rings SeekB00st's Avatar
    Dec 09 2008
    A tricycle
    Nofolk VA (Its Hood Here)
    Same thing I was thinking.
    Let alone, this is still use full knowledge.
    I did the tuning my self on my turbo, so my speed limiter still exists.
    I feel that I'd run out of gearing before we top out this 1.8t anyways.
    Put Werk Here
    [/SIZE]
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by seanj130 View Post
    What? the limiter stops the car before redline... either you're lying, or your car is actually chipped (but I can't really see a 200hp A4 hitting ~150mph, I could be wrong though!)
    because racecar.
    Veteran Member Three Rings T0mat3's Avatar
    Oct 05 2008
    Montreal, QC, Canada
    Uhm... my old 2.8 hit the speed limiter no problem NOT going down hill, Didnt try it with the 1.8t.
    Sep 05 2008
    Pittsford, NY
    Quote Originally Posted by Kyle H View Post
    No chip.. it topped at 129.. I thought that is what it was limited to
    Best regards,
    Sean.
    Veteran Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 4.2QM, 01 Nogaro RSFaux Avant, 15 Q7 TDI Sport Edition
    Valparaiso, IN
    Quote Originally Posted by .Mad Hatter. View Post
    Me
    Brilliant Black 99.5 A4 Project V8
    Nogaro Blue 01.5 S4 B5 RSFaux
    Glacier White 15 Q7 TDI Sport Edition
    Poopoo Brown 80 5000s Diesel
    Audi R8 certified technician - PM for work local to Chicago/Northwest IN
    Alex
    Active Member Two Rings TheEugeneKam's Avatar
    Jun 24 2010
    Mississauga/Ontario/GTA
    129 km or mph, i hit 210 km before, so just shy above 130, before i chipped mine, now i do the same hitting, just faster :D
    Sep 05 2008
    Pittsford, NY
    I hit 129 MPH.. KMph would be easy to do..
    Best regards,
    Sean.
    Veteran Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, 2022 Outback, 97 civic ex(blew up), 95 Toyota pickup(sold)
    Parkland,FL
    fastest I hit 3 years ago on a k03 with APR chip was 145 and i blew the turbo...i don't recommend you run a k03 with almost 100k that hard lol
    99.5 A4 1.8TM AEB Fronttrak - Volcano Black Mica - AutoFlex'd Signal Green - E85 - Clutchmasters 725 series twindisk - ID1000cc - Precision 5858 cea Ball Bearing Turbo - JE Pistons/IE Rods - EurodyneMe - Coilovers - AWE DTS - 034 Mounts - Team Dynamic Wheels -Nitto INVO -Working @ DipYourCar.com - Usp Motorsports -
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    but that's not redline?
    because racecar.
    May 07 2007
    keep in mind the chip raises the redline...
    Sep 05 2008
    Pittsford, NY
    Top estimated speed: 130 mph (203 kmh) - Electronically limited for North America
    And i had no revs left, i was right up to the red. not into the red just right up to it.
    Best regards,
    Sean.
    Nov 16 2009
    Sandy eggo
    I topped my car out at 130 this weekend mods are in the sig.. My car had alot more to give..It was like hitting a wall when i hit the limiter...
    How do you disable it through vagcom? I cant have a check engine light here in socal to pas smog
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    149 MPH. GIAC chip and KW suspension (Not a power adder but definately more confidence inspiring). I wasn't topped out in RPM , but she wouldnt want to go any faster than that.
    MontrealAudiClub
    Oct 21 2005
    y
    Quote Originally Posted by Shhmaudi View Post
    Not possible thru vagcom.
    Easiest way is, use a switch. Switch it on then reset code for smog. Then switch it off after passing
    *switch to connect/disconnect the VSS wire.
    Nov 16 2009
    Sandy eggo
    Quote Originally Posted by ricekikr View Post
    hmm not a bad idea... However, i shouldnt be going over 130 anyways... Unless im running the cops which is hopefully never
    Apr 26 2008
    Philippines
    Quote Originally Posted by Dan[FN]5857 View Post
    Does the SAFC work with the AEB? What settings did you use? thanks!
    Sep 12 2008
    South Central PA
    Quote Originally Posted by Leospeedworks View Post
    I never installed it. My buddy took it out of his turbo Honda and gave it to me, and I found out that I couldn't properly use it on my B6, but from what I understand, it'll work on B5s. so its just been sitting in my trunk for like a year.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
