Results 1 to 9 of 9
    Established Member Two Rings 97_a4_1.8t's Avatar
    Jun 03 2009
    Homer glen IL
    s4 brake upgrade
    got a few questions i can get the full front subframe with axels, hubs, rotors, calipers, etc.. but also i can get the rear sub frame to with everything the question is would i be able to put the rear subframe with out the rear end and axles or will it not work?
    1997 a4 1.8t front trash auto 176k
    May 09 2009
    Syracuse, NY
    I'm not sure it would be worth all the effort... Your rear brakes don't do a whole lot...
    Jun 03 2009
    Homer glen IL
    yeah but one of my rear spindles is a bit messed up and screw up wheel bearings every now and then and plus its gonna be really cheap for it and i cant find anywhere other than audi that has rear spindles
    Jun 03 2009
    Homer glen IL
    so would i be able to swap in the rear sub frame?
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    Why do you want to swap the rear subframe? If you want s4 brakes in the rear just get adapters from 034, s4 carriers, calipers and some 300mm rotors along with brake lines and you are good to go.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    swapping rear subframes is not fun and sounds like a lot of work for just a brake upgrade
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Oct 15 2010
    Fairlawn, OH
    Quote Originally Posted by 99blueb5 View Post
    he only needs to swap the front spindles and and maybe the half shafts or he could go with something custom that bolts right up
    Sep 17 2005
    Fremont, California
    If you do go ahead and swap subframes, check out our Subframe Bushing kits. We offer a stiffer then stock, and full motorsport aluminum set. I don't recommend the motorsport for daily driving, but the stiffer then stock will keep good ride quality and offer way less deflection between subframe and chassis.
    I have an S4 front and rear subframe on my project A4. Its not a terribly fun job.
    http://www.034motorsport.com/chassis...s-p-18142.html
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    Quote Originally Posted by Max@034 View Post
    Aligning the damn holes of the subframe after installing the new bushings were a biotch. I went with the full aluminums, but I cannot tell you how the ride. The do looks pretty as hell though!
    MontrealAudiClub
