Results 1 to 3 of 3
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    Anyone knows whats up? Running lean at WOT, B2 o2 reads .0435 CONSTANTLY...(more)
    Bank 1 is still running somewhat normal, but bank 2 shows .0435 while cruising, idle, and WOT. Even when B1 is showing 0, B2 is still showing .0435.
    Brand new plugs and coilpacks, injectors have about 1k miles on them. New EV14s from VAST. I swapped ICMs with no change.
    Also, I am getting code 17704 coolant temp. but it is brand new and my thermostat is stuck open so I think its from that.
    Any ideas? 02 sensor? EGTs are coded out. MAF is normal readings. Thanks.
    B5 S4 Built motor GT28X's
    08 3.2 A3 DSG DD
    Sep 11 2009
    NE
    maybe your o2 sensor is shot?
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    O2 sensor is shot if it gets a constant reading.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
