Oil: Motul 300V 4T Factory Line
Viscosity: 5w40
Behold the power of high-end lubricants. Repeated WOT, minimal highway use, regular "short trips", and several race days. Everything looks great even at 60k on the motor! This seals the deal...will use the same oil at my next change. You can also see that it has barely sheared with my driving style; 100C kinematic viscosity is still a light 40/heavy 30.
Previous owner fed it OEM Castrol and Mobil 1 for the first 50k. Just proof that most modern synthetics are over-engineered for the vast majority of drivers.
(Note that this was a sample of partially-used oil. I am trying to determine the change interval on this stuff. I did not drain the oil and replace at 1,900 miles!)
