Results 1 to 8 of 8
    Active Member Two Rings ItalianAudi77's Avatar
    Jun 28 2010
    Lansing, MI
    Intrument Cluster Clear Plastic
    This past weekend I tore apart my Instrument Cluster because the plastic was really dirty and it annoyed the crap out of me. It was really easy to do but once I finally got it apart, I wasnt able to clean the glass well enough to my liking. There is some spotting that just wont clean off. Anyone know where I can get the front trim piece that includes the clear plastic? I cannot seem to find it on any of the normal websites where we can get OEM parts. I am sure the stealership will just bend me over. Any pointing in the right direction is greatly appreciated!!
    Mike
    Black 2007 Audi A4 3.2L | quattro | VAG'ed
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    If I'm not mistaken it's not glass, but a clear polycarbonate (plastic). There are various plastic polishing compounds that can be used to get plastics optically clear. You would need to purchase a couple of different compounds and some soft buffing pads for a low speed orbital polisher.
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Senior Member Two Rings STONER's Avatar
    Sep 02 2009
    B7 A4, B8.5 S4, A3 Tdi
    Layton/Utah
    Do you need the plastic trim piece that covers the screw holes? If so pm me I have one.
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    Get scratch remover compound and clean cloth, rubber in like you would wax a car and the spot should disappear, that is cheap alternative, dealer will sell you new cluster, they don't sell just plastic, ebay is your friend
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Established Member Two Rings daudic's Avatar
    Jul 06 2009
    2007 A8l. 2003 TT Roadster. 1985 Yamaha Vmax!
    Lancaster/Ohio
    You should make a DIY since you have all the pics.
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    Quote Originally Posted by daudic View Post
    x2
    yes please, if you have time.
    i feel your pain, it annoys me too.
    Jun 28 2010
    Lansing, MI
    Quote Originally Posted by apatchin View Post
    x2
    Now I did not make this DIY, but I did follow it and it worked out for me!!
    http://account.audiworld.com/showthread.php?t=2377674
    Established Member Two Rings VdTechnofreak's Avatar
    Jun 02 2010
    1973 Mini (BL, ftw!)
    East Tennessee
    don't know if it works, but that headlight cleaner sh*t might also fix it (if that stuff really works)...you know, the kind that is supposed to clear up scratched headlight lenses/housings.
    For future reference, don't use harsh paper on the cluster, microfibre rags work better and won't scratch it.
    2006 Brill Red B7 2.0T 6MT, Color DIS, factory RNS-E (upgraded to version 0200), BT, Adaptive B-Xenon, Koni FSD/Eibach springs, RS4 rearr swaybar, H&R 32mm front swaybar
    2003 Dolomite Gray TT 1.8T 225hp Cpe 6MT--da Wife's daily driver, with Fogs as DRL's, Votex front bumper
    1973 Mini--1275cc, HIF44,1.5° rollertip rockers, stage 4 head, LCB, RC40, solid mount front subframe, poly mounted rear, negative camber all around, adjustable ride height coil spring conversion.
