Originally Posted by
joe dub
you need to load up the caliper pins with grease.
DxC
It's the springs that hold the rear pads. Common issue
First off, although one of these posts was made a long time ago... THANK YOU!!
mrmule
Did greasing the pins get rid of the rattle?
For me it did. I had the same issue a few months after a recent brake change, the rear would make a little metallic rattle over uneven surfaces. However if I applied the ebrake and went over those same roads again it would be quiet. So i was able to narrow down something with the rear brakes.
I cleaned the pins and reapplied a generous amount of brake grease, sometimes pulling them out and reapplying a few times. You can grab the pins when inserted and check for side to side movement, before I pulled the pins there was just barely a little movement, after regreasing there was none. I then checked the boots for wear, then reinstalled everything (if you put too much grease you'll know it as the pins will try to self eject and the boots will look like the Michelin Man upon compression). I also bent the pad springs out a bit to allow a tad more pressure, and applied a dab of brake grease to all contacting surfaces. Rattle is now gone.
