Results 1 to 9 of 9
    Mar 17 2008
    new jersey
    034 high flow cat trouble
    Question for anyone out there. So I just installed an 034 high flow cat with new rear o2 sensor and am getting this code now:
    Address 01: Engine
    3 Faults Found:
    17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
    P1176 - 001 - Upper Limit Exceeded
    18010 - Shareware Version. To Decode all DTCs
    P1602 - 002 - Please Register/Activate - Intermittent
    16523 - Shareware Version. To Decode all DTCs
    P0139 - 001 - Please Register/Activate - Intermittent
    Readiness: 0000 0001
    any ideas what it could be?According to ross tech its * Intake Air System leaking
    * Oxygen Sensor(s) and/or Oxygen Sensor Control faulty, but I was unable to find any leaks and the sensor is brand new
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Did u plug in the correct sensor in the front and rear?
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Four Rings mnkyA4's Avatar
    Aug 10 2004
    The City
    Isnt the first coded related more with the front O2 sensor? Also are you running the spacer for the hfc?
    03' 1.8T A4 Avant Tiptronic ----- SOLD!!!!
    FUTURE: 2013 Ibis White Q5 3.0T
    Mar 17 2008
    new jersey
    yup i rechecked and made sure they were correctly plugged in and positioned and I am running a spacer on the rear o2. The only reason I thought it might be the rear is because I never got the code till switching out the rear and the front is relatively new, less that 8,000 miles on it
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    bump!!!!!!! but this thread seemed to fit fairly well with my problem
    OK so I am also getting a P1176 CEL, P1176 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
    about 72k- chipped to APR stage 1+ with bosh 380cc (I know there not TT225 386cc's but I haven't gotten around to replacing them)
    about 81K- 034 HFC installed (got the expected rear O2 CEL, about two weeks after the HFC got re-flashed to 2+, cell gone)
    today 82k- get the P1176, been driving around a lot today as Seattle is getting some good snow (28*F), and having quattro means that I get to shuttle people around
    so I see that it is commonly a bad O2 sensor, however doesnt the APR 2+ code out the rear sensor?
    I also heard that this code rarely is caused by a bad MAF, so I unplugged MAF and drove about 10 miles (very fun having no traction control in the snow )
    before when the CEL was thrown my long term fuel trim was 13%, short term fuel trim 0%
    after driving for ten miles the long term fuel trim was still very high, 14%, this leaves me to believe the MAF is fine
    so, im guessing it is the injectors that is causing my car to run way to lean, also leaves me with a $300 test to see if I am right
    anyone else have any thoughts into this matter
    Please Drive Right
    Sep 10 2011
    None
    Quote Originally Posted by Pothole View Post
    Time to start charging!!! Make some money off your inconvenience!
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    you know there is a button that does this too right? lol
    also if you are using a J bung or an O2 spacer AND you have the code 'written out' by your software, its not actually written out- just the values it looks for are different, so spacing it can cause problems. well at least that's what my tuner told me...
    just my $0.02
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Jun 02 2008
    I never put a spacer on the O2 because I knew the 2+ file would delete it, wonder if adding one in will help or make it worse
    I unplugged the MAF to see if it was faulty, I didnt actually know that it played a part in the traction control until I was getting back onto the free way
    Please Drive Right
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    if the 02 sensor has actually gone bad, the code will still come up even if the error omit software is in place. ask me how I know.
