Results 1 to 33 of 33
    Veteran Member Four Rings ilko's Avatar
    Oct 20 2007
    997TT, 993, W211 E55 AMG Wagon
    Upstate Manhattan
    Brake Caliper/Rotor Upgrade Questions - UPDATE 10/27 - MORE QUESTIONS!
    Let me begin by saying I'm seriously disappointed with the 1.8T brakes. I have an avant and usually carry a couple of passengers, so it's a relatively heavy car - over 4,000 lbs. The stopping distances are just silly. And yeah, I'm a little spoiled, I have a Porsche with 2000 HP (not a typo) worth of stopping power that can just stop on a dime. But the Audi is the car that I drive my family with and want to have something more confidence inspiring. I've tried different pads, I use ATE blue brake fluid, etc. but I've noticed no noticeable improvement. And it's not like ABS kicks in when I mash on the pedal either.
    So I'm thinking of upgrading the front brakes to the B5 S4 calipers and rotors. I've decided to use those because they are relatively affordable and easy to find, but I'm open to hearing other options as well.
    My questions are:
    1) Is this a plug and play application or will I need to get caliper adapters as well? Any thing else?
    2) Do I need a new brake master cylinder to handle the larger brakes?
    3) Do I need to adjust the brake bias?
    Thanks for your help!
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Previous: 993 Carrera 4S / 964 RS America / 964 Carrera 4 / 944 Turbo / MK4 Golf R32 / C5 allroad / B6 USP Avant
    Senior Member Two Rings BRSox307's Avatar
    Aug 16 2007
    B5 S4 fronts are plug and play. No modification needed. I had that setup and recently upgraded to B6 S4 front and rear and I am very happy with my decision. Those is also plug and play.
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    pictures of the super porsche... or it never happened.
    as for the brakes: Click Click
    all info you need is there.
    Sep 13 2008
    Western Chicago Burbs
    If you can find 04-08 S4 brakes you will be happy. they are disgustingly powerful compared to the brakes that were on my A4
    not saying the B5 S4 brakes aren't powerful because they are
    Oct 20 2007
    Upstate Manhattan
    Quote Originally Posted by JEENYUS View Post
    Thanks for the link!
    It did happen ;)
    Track rat, loved and missed dearly:
    Replaced after the baby was born with this:
    Thanks for your replies guys!
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Veteran Member Four Rings nofearhawk's Avatar
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    Go with B6/7 S4 brakes, the price is fairly low for these and the B5 S4 calipers are wider and may limit your wheel choices.
    Oct 20 2007
    Upstate Manhattan
    I'll look into the price difference of the calipers. Good point about the wheels, thank you. I have USP wheels, does anyone know if that would be a problem?
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    ^ Won't fit, you need a small spacer to clear B5 S4 brakes, b6/7 s4 no problem
    Oct 20 2007
    Upstate Manhattan
    Will a 5mm spacer be enough? I'd rather not get longer wheel bolts as well.
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Veteran Member Three Rings Mani's Avatar
    Dec 21 2009
    2008 BMW 335i - Dinan Stage 3
    Irving, TX
    I would recommend B7S4 brakes if you can get one. Much bigger rotors so better stopping power than B5S4. I am sure B5S4 brakes are better than stock one but still... B7S4 is the best OEM upgrade IMHO.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    5mm will be more than plenty for "most" wheels.
    I'll have my B5S4s front brakes available in about a month or so, if you want it.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Established Member Two Rings Zaloo's Avatar
    Nov 02 2009
    Lexington KY
    I have the b5s4 brake calipers with adam's rotors - it was night & day compare to the stock a4 brakes. This was before the b6s4 brake swap became well known so I'd say go for the b6/7s4 now unless you come across a good deal.
    2005 Audi A4 1.8TQ Tiptronic, APR Stage 2+ w/ shit tons of mods. AZ wouldn't let me list everything...
    Dec 01 2007
    Orange County, NY 10918
    Quote Originally Posted by Zaloo View Post
    x2 i have the same setup. Not impressed with the Adams Rotors though. But if i was to do it over again i would get B6/B7 s4 brakes.
    5mm spacer should make the USP wheels fit. you need like a 40 et or less on some wheels
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Just had my B6 S4 brakes installed last week. Love them. ATE "atomic slotted" rotors.
    P.S. - this might be most posts in a brakes thread without someone typing "breaks." Kudos all around.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Oct 20 2007
    Upstate Manhattan
    Quote Originally Posted by A4 Moda View Post
    PM sent.
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Nov 02 2009
    Lexington KY
    Yeah they tend to be more looks than performance but I couldnt beat the price at the time
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    Quote Originally Posted by kwimberly View Post
    am interested to see pix with those rotors.
    trying to decide what rotors i should get as well.
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    Not my car, but my former brakes, when I had them they were copper. The ATE rotors are excellent quality, made in Germany as well:
    Oct 16 2006
    Naperville
    how come no one suggest the b7a4 calipers? To fill you in, its similar calipers to the b6/b7 s4s but with different carriers. rotors are the same as the b5s4 rotors (320mm). If sometime down the line you want the 345mm rotors, you can buy new brackets and youre all set.
    Dec 21 2009
    Irving, TX
    I had B7S4 brakes installed with 18"USP wheels. I didn't need any spacers.... crappy iphone 3g pictures...;/
    Jun 10 2009
    Quote Originally Posted by nofearhawk View Post
    thanks, finally get to see how they look behind the wheels.
    definitely a choice to pick along with the 'race' (double slotted) from adam's rotors. what to choose, what to choose?!?!
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    I'm surprised nobody's mentioned how bad the b5s4 brakes are with brake dust. I would DEFINITELY get b6/7s4 brakes for the oem upgrade.. Stopping performance will be slightly better for street use. The b5 brakes seem to be better on the track (i've tried both;-) from less brake fade but ...
    Quote Originally Posted by ilko View Post
    that first link no worky. and please divulge the setup on a 2khp Porsche... Im imagining a borrrrred flat 6 with a GT47 frame?
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    BTW 993 Porsche Turbos, especially the Turbo S, are probably my favorite cars of all time. I dream of owning one in the not too distant future.
    Jun 11 2005
    Yeah B5S4s, Horrendous. Seems to just bite the hell out of those pads and leave everything else dying in its wake.
    Quote Originally Posted by ThirdStrike View Post
    2003 1.8T
    Oct 20 2007
    Upstate Manhattan
    Fixed the link. The 2000hp is the measured stopping power. That's with the stock set up of the C4S as well as 4-channel ABS, same as the 993 Turbo. I upgraded the RS America with 993TT front brakes, and regular 993 rears. 2-channel ABS.
    Now back on topic, I ended up getting the B7 A4 front brakes instead of the B5 S4. Two questions:
    1) I noticed that the carriers protrude a bit, so does anyone know if I will still need spacers for the USP wheels?
    2) I'm thinking of upgrading the rears as well. Do the B7 A4 rear brakes bolt on directly to the B6 1.8T?
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    No spacers on the b7 brakes. I'm clueless about the rears tho.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    1 - no
    2 - yes
    Oct 20 2007
    Upstate Manhattan
    Excellent, thanks guys!
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    I can assure you AR will perform as good as any other replacment rotor on the market.
    but our machining, countless options, coatings, and service will top any!
    feel free to email any questions you may have my way...
    thanks
    -a
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Dec 06 2007
    No and no
    you do not need spacers as B7 A4 front brakes are not very large(caliper wise)
    and yes the B7 A4 rears are plug and play given that you have the carriers. The only things that won't work are the dust shields which aren't necessary as the OEM B6 ones are more than sufficient for the job. I have a set on my car and they have been great.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    I did B7S4 brakes this spring and they're fantastic. SOOOO much better than the garbage brakes supplied on the B6 1.8T's. Much more confidence stopping but the stock pads were horrible for brake dust. I would have to wash my wheels every 3-4 days. I switched out the pads to some Hawk HPS's and they're much less dusty.
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    Quote Originally Posted by mani View Post
    You sure those aren't b7 a4 brakes...they use the same calipers. Discs look a bit small...
    Mar 27 2005
    The Cold North
    if you still run crappy pads it doesn't matter what rotor and caliper combo you run. Step up to a decent pad if you want more stopping friction...
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
