Results 1 to 37 of 37
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    weird noise behind dash
    Not sure if this is a cooler weather thing or not, but I have this strange noise coming from behind the dash. I can only hear it when stopped and at idle. Its like a relay opening and closing, or something similar. The even weirder thing is when I stop, cut the engine, remove the key, and open the door...I can still hear something happening behind the dash...like a servo opening and closing a damper or something.
    This happens whether the climate control is on or off. I'm not terribly concerned about this...its more of an annoyance than anything else. I've owned this car since new and am quite in tune with the way it behaves, the sounds it makes, etc...so when it starts making new sounds I get curious. And the fact that I hear little motors (or something) making sounds behind the dash when the engine is off and key is removed is weird. I haven't stayed around long enough to learn how long this goes on for, but I worry about the battery being used needlessly.
    Anybody else hear weird noises like this coming from their dash?
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Oct 22 2010
    central florida
    I just bought my A4 last friday and noticed mine does the exact same thing. I wasn't sure if this was common to all cars or mine and it's unknown history. I will be glad to hear what it is though. I was assuming it was something to do with the climate control.
    Veteran Member Four Rings Mantvis's Avatar
    Jun 05 2009
    mk1 Audi TT 180hp, mk1 Audi TT 225hp, mk4 VW GTI
    Chicago, Naperville
    same thing with my TT. so im guessing it is the climate control
    If you don't need both hands on the wheel, then you're NOT driving.
    Jul 15 2007
    Mount Rainier, MD
    But the climate control is OFF.
    ~Eric
    Jul 15 2007
    Mount Rainier, MD
    Quote Originally Posted by tyroneshoelaces View Post
    I just bought my A4 last friday....
    Congratulations!
    ~Eric
    Jun 05 2009
    Chicago, Naperville
    off and on. dosnt matter
    Established Member Two Rings Allhailpoptart's Avatar
    Mar 16 2010
    NH
    My '03 does this constantly. I'm fairly certain it's something wrong in the climate control system but I have no idea what just what that is yet. It hasn't caused my heat/AC to not work yet so I'm not really 100% interested in the potential of pulling apart the dash to try and fix it. I've looked around a little bit but haven't really come up with much.
    Every time I do a full VagCom scan I always pull back these codes and judging from the sound I'm willing to bet the system is testing these, or doing something with them, to make that noise:
    Address 08
    Controller: 8E0 820 043 L
    Component: A4 Klimaautomat 1016
    01809 - Actuating Motor for Temperature Flap: Left (V158)
    41-10 - Blocked or No Voltage - Intermittent
    01841 - Potentiometer/Actuator for Temperature Flap: Left (G220)
    30-10 - Open or Short to B+ - Intermittent
    01274 - Air Flow Flap Positioning Motor (V71)
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    1995 URS6 Avant | 2.6L Eurospec Sport Stroker | EFR7163 @ 25psi | Tuned by EFI Express
    Jul 15 2007
    Mount Rainier, MD
    Hmmm. Thanks for that post. I'll VAG my car when I get home tonight!
    ~Eric
    Jul 15 2007
    Mount Rainier, MD
    Quote Originally Posted by Allhailpoptart View Post
    Yes...I am getting this code (1.5 years later). Doesn't seem to effect the climate control system at all! I'm certainly not going to rip the dash apart chasing down this gremlin..although now I really wonder if there is something blocking the flap...like a dead mouse or something.
    ~Eric
    Established Member Two Rings chitownsports's Avatar
    Mar 28 2010
    I need $$$ for cars
    Houghton, MI
    Happens to me too, but no codes last time I checked
    !!!Denim Blue Baby!!!
    May 25 2012
    MA USA
    I had same thing and recently got my ross tech for a different check engine light reason. I saw a thread elsewhere that said to recalibrate the basic settings of the AC module. So I plugged in, went to AC module, found basic settings, calibrate (I think it was called calibrate...) and after it performed that recal that was fully automatic and took 1 monute for system to just move the flaps to full open and closed and read the pots, the codes are gone and the noise is gone! Try it.
    Veteran Member Three Rings Mr.Avant's Avatar
    Jun 18 2012
    Edmonton
    I too notice this odd noise. Never when the car is running but always after turned off with key pulled out. Always assumed it was the climate control "flaps" for directing air through the different vents cycling. Glad to know its not just me.
    03 A4 1.8TQ STD | Atlas Grey | S4 Alcantra Reacro's | S4 Bi-Xenon Lights
    Motoza Stg 1+ | TT 386cc injectors | Unitronic 3" Downpipe+HFC | Magnaflow 16601 | S5 coilpacks | SAI Delete
    JHM Short Throw Trio | BFI GS2 | Pioneer Navi | S-Line Wheel | Hardwoooood
    H&R Front Springs w/ ECS Coilover Sleeve | Statis Rear Coilovers | 3sdm 0.06 | 18x8.5 | et 27 Rear 32 Front
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    its loud and annoying at first but now i just ignore it.
    Jul 06 2012
    Pennsylvania
    I found this youtube video by chance a little while ago that seems like it match up with the issue everyone here is describing.
    http://www.youtube.com/watch?v=rQj5un6bjbM
    Description of the video says the part# he found that was faulty:
    "I would hear a clicking sound after turning the car off, key out. After removing the glove box I was able to locate the clicking component. My part number that failed on me was 8E1820511C"
    I have the same noise coming from mine as well at the moment. Need to look into getting the dash disassembled and take a look. Hope this helps.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    I have the same noise and it mainly happens after I shut down the car. I've learned to live with it as it doesn't throw any codes or seem to cause any problems. Any body have any more detailed info on exactly what this is and if its worth tearing into the glove to resolve?
    Jun 18 2012
    Edmonton
    Quote Originally Posted by WildGoose View Post
    Thats not the noise mine produces... Mine sounds more like the when you move the CD's through the CD changer.
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    blown servo- ive taken the dash apart and watched this little pathetic green servo arm weakly try to go back and forth whining like a tard.
    like dis:
    i do plan on relplacing it..... soon.
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Did this part actually fix the problem? Anyone else have any solutions to it?
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    May 11 2008
    Columbus, OH
    Here is a good read with a picture behind the glove box. I'm getting more convinced its the defrost motor. It's where the sound is more profound is in the middle of the dash by the windshield.
    http://www.ebay.com/itm/Defrost-Flap...-/280964782566
    Jun 08 2007
    GLI
    Orlando, Fl
    Mine did this for years, one day it just finally stopped and it took the a/c with it. Once it stopped I no longer had a/c.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    May 11 2008
    Columbus, OH
    I finally took my glove box out and its definitely the defrost servo motor. The control arms are either stuck, which I doubt, or the motor is too weak to move the arm and flaps. I ordered a used but working motor from ebay and will post results. 8E1820511B is the part number. This also showed as a fault in VAG-Com which only solidified the diagnosis.
    As far as noises behind the dash...taking off the glove box literally takes 5 minutes. Just 9 - 8mm bolts and all really easily accessible with extensions and a ratchet.
    With all those control arms behind the glove box it all kind of looks like the game Mouse Trap. lol
    Aug 21 2009
    Good info here Thanks coowhip!!
    Jul 15 2007
    Mount Rainier, MD
    Quote Originally Posted by coowhip View Post
    I wonder when we'll see the 034 "Density Line" control arm kit for the servo motor. Mine has way to much slop.
    ~Eric
    May 11 2008
    Columbus, OH
    Performance line of AC and Heater servor flap motors! I'd buy it!
    May 11 2008
    Columbus, OH
    FIXED! Very easy and straight forward to replace that little servo motor. If you have a bad or malfunctioning motor behind the dash, it should show up as a code in VCDS in the "auto HVAC" controller.
    Veteran Member Three Rings Hamotee's Avatar
    Oct 30 2005
    Other German Stuff
    Athens,Ga. Clemson,Sc
    Coowhip, Do you known which codes were associated with the servo motor? I started having this same problem today with the following codes:
    01809 - Actuating Motor for Temperature Flap; Left (V158)
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    I wanted to make sure that the servo motor you replaced could be responsible for these codes. Thanks.
    How to account for this massive success? Pure luck? Transcendental meditation? Machiavellian manipulation? Aerodynamics? High colonics? We haven't the slightest idea. -P.L. Newman
    May 11 2008
    Columbus, OH
    Mine was the defrost flap motor. Yours sounds like a different one. You need to remove the glove box and get all up under there to hear and see which one isn't adjusting. Write some part numbers down and do some searching or call the dealer to associate the part number with the name of the code. There are about 4-6 little motors behind the glove box. Most on the left side and maybe 1 or 2 on the right side.
    Do you have a VAG-COM? You can run self tests on all those motors for the HVAC. Maybe it will help you determine which one it is.
    Veteran Member Three Rings Delasangre4231's Avatar
    Nov 22 2012
    Portland, Oregon
    I have this problem too, I will be investigating behind the glove box. I do notice that if I stay in the car and use the key fob to set the alarm the noises stop after 5 seconds or so.
    May 11 2008
    Columbus, OH
    Are you hearing it constantly adjust while you're driving?
    Nov 22 2012
    Portland, Oregon
    Hard to say with road and engine noise, but I believe so yes.
    Oct 02 2006
    Wadsworth,OH
    My 03 seams to have this issue as well. Almost sounds like the throttle body is trying to align or something. I'll have to pull my glove box and see what's going on.
    Jason
    May 11 2008
    Columbus, OH
    Yea, only way to tell is with the glove box off. Maybe even start the car, then go underneath to see which one is trying to adjust but can't. If it is making noise like a toy low on batteries, it will need replaced. Take the part number down, google search, then get that part! Post up what you find. You can always use VCDS and perform output tests on all the flap motors.
    Jason, with VCDS you can check codes to see which one may be causing your issue. Should be the HVAC controller.
    Oct 02 2006
    Wadsworth,OH
    Excellent! Thank you for the information.
    Jason
    Senior Member Three Rings GTA's Avatar
    Feb 08 2013
    2003 Audi A4 1.8TQ, 5-Spd
    Toronto, Ontario
    I have written about this in a DYI section on this link:
    http://www.audiforum.ca/a4-b5-b6-b7-...leaning-72039/
    Essentially, as the flap motor units age, they may accumulate dust because they're not sealed units. I resolved my flap motor issues and all associated noises with household items, basic tools and some effort. The best part is that I didn't spend a dime and didn't have to replace anything.
    Other than the noises, I wasn't getting good heating or AC cooling and I traced it to the flaps opening and closing on their own like they were possessed.
    I hope this helps and good luck!
    Active Member One Ring KewlAid83's Avatar
    Aug 16 2021
    me none my gf 2017 Toyota Rav 4
    West Virginia, USA
    I believe I may have it too... happens when turn car on and when shut it off but I haven't found it yet . . . please lmk if you figure it out
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Hope he's still on. That last post was over 7 years ago.
    Clicking Sound intermittently
    Hello,
    I have a 2013 S5 and I have been getting this weird clicking sound coming from the inside of my dash. It seems to effect the drivers side door tweeter and sometimes the mid range speaker.
    This seems to be correlated to me loosing sound from the same speakers when it happens. I was using the original head unit/MMI Display and now I am using the RSNAV (beautiful). I get the same symptoms with both setups. I replaced the tweeter in the door and it still is an issue. I recorded it yesterday.
    I have had this car since she was born and this problem started this past summer.
    Have you or any of you guy ran into this issue?
    Here is a video of it:
    https://youtu.be/mFrXH6HdyYc
    Please check it out and tell me what you think. 🥺
