Results 1 to 6 of 6
    Established Member Two Rings mattnucci's Avatar
    Apr 30 2010
    Mentor, OH
    Secondary air pump and check valves
    I know it is possible to delete the secondary air pump/egr/check valve crap out of my engine bay, but what does this actually do to the car. Any emissions issues or engine issues i should be aware of? I want to clean up the engine bay and delete stuff but don't want to hurt anything possibly. Thanks!
    Matt Antenucci
    Cleveland, OH area
    02 A4 1.8T Air Lift full air ride kit.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Matt, read over this thread VERY CAREFULLY: http://www.audizine.com/forum/showth...simplification
    To get rid of some of the CELs, you may need to get the ECU specially programmed by a tuner to simply "ignore" the existence of an item and report good ready codes. One caveat to that is that more and more emission testing centers are getting smarter and picking up on where parts should be located in a car as well as testing the ECU to see if it has been tampered (having ready codes come back immediately after a reset).
    Another option is to get your car registered in a county that doesn't do e-checks. Then go to town cleaning up everything.
    USP CLUB MEMBER #34
    Apr 30 2010
    Mentor, OH
    Damn, thats what i was afraid of, oh well i guess i will wait another year when i have enough money into it to get collector plates. Thanks for the info
    Matt Antenucci
    Cleveland, OH area
    Active Member Two Rings dubswede's Avatar
    Mar 27 2010
    mn
    you can get collector plates after only 10 year in Ohio?
    if that's true and they don't require that you have another non-collector car, you've got it easy.
    Apr 30 2010
    Mentor, OH
    As long as you spend a crap load of money on it and have the receipts to back it up and show that it is essentially a show car or weekend car then you can get collector plates. I have a daily driver. The Audi is my fun car so no worries there.
    Matt Antenucci
    Cleveland, OH area
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Lol its simple to rid yourself of the sai on this car. It was kinda hard to hide that it was missing on my old 2.0 since the pump is at the top of the motor between the motor and the radiator. Just a giant gap with a bracket that holds nothing was left there.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
