Results 1 to 15 of 15
    Veteran Member Three Rings wildbill's Avatar
    Jan 25 2010
    work
    will b6 s4 seats fit
    anyone?
    boost. a new band aid by Johnston&johnston
    Senior Member Two Rings windsorblue's Avatar
    Jun 21 2007
    Brunswick, Maine
    They are not a bolt-in swap. The mounting is completely different.
    Jan 25 2010
    work
    but can i weld them in?
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Yes you can
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Jan 25 2010
    work
    i cannot find a seat for the life of me, my crappy mechanical one broke and so i put a white one in for the mean time...anyone know a good place? classifieds have been a strike out
    Veteran Member Three Rings SeekB00st's Avatar
    Dec 09 2008
    A tricycle
    Nofolk VA (Its Hood Here)
    Quote Originally Posted by wildbill View Post
    Try Vwvortex. Or try to get just an aftermarket pair.
    Anything can be put in. Hope you are good at welding seems.
    Put Werk Here
    [/SIZE]
    Jan 25 2010
    work
    im trying to avoid AM. and it is hood in norfolk!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Why not go B5 S4 which is much easier?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings danphines's Avatar
    Dec 23 2008
    2000 ATW 1.8TQM
    Rehoboth Beach, DE
    I have a full black leatherette interior you can have for free. drivers side has the tear, passenger and rear are perfect. they are heated as well. You would have to come to MD to get them though.
    Unitronic stage 2, 3 inch turboback, Stasis SS coils...
    May 16 2008
    South Texas
    It's possible if you want to loose all safety features and adjust ability.
    Active Member Two Rings Finneid90's Avatar
    Jul 21 2010
    Norway
    What about S3 seats? Will they fit? Probably not but...
    Audi A4 B5 1.8T Quattro GT2860rs++ (277whp/371wtq @ 25.4psi) - VRT swap in progress -
    Nov 30 2008
    06 Wrx
    Olympia, WA
    Quote Originally Posted by Finneid90 View Post
    Like was said earlier. Not as direct of a swap as the B5 S4 seats would be. But with time and money, almost anything can be made to fit.
    Wildbill, if you do go that route (B6) could you post up just a vague rundown of how you go about it. I've been wanting to do this for a while, but no one really has done it, and i don't really have the skill/knowledge/resources to just go out and see what happens. lol. I have all carpet out of my car right now too, so that makes it quite a bit easier to work with.
    Check this article out. Its named " OEM RS4 Seats Install " http://www.audiworld.com/tech/int.html This say's its for a B5, but the seats look the same as B6 S4 seats... (yes i do realize they are not, just saying they LOOK the same styling
    Jan 25 2010
    work
    yeah just cost the same as a recaro....so id buy x fighters at that point, but if i do something stupid complicated i will for sure do a write up
    Dec 09 2008
    A tricycle
    Quote Originally Posted by Scotty@Advanced View Post
    You can weld the sliders/rails. Allowing you to retain adjust ability.
    Safety features?
    I'd much rather have my seat welded in place in comparison to how ares are held in. I'd say a welded seat would be a lot safer.
    Put Werk Here
    [/SIZE]
    Jan 25 2010
    work
    agreed....how is a correct weld not safe compared to two little bolts?
