Results 1 to 10 of 10
    Established Member Two Rings mikeyb35's Avatar
    Jul 25 2009
    Colorado
    RS4 Wheels and tires
    So I have an opportunity to get brand new OEM RS4 wheels and tires. The only problem it's the stock tire size 255/35/19 and I have a B6 A4. So before I pick these up I need to know if there is anyone that might need these tires or trade for 235/35/19. Let me know
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Even with 235's on them you may need to roll fenders and/or get adjustable upper control arms to run more camber in order to minimize rubbing. The face of an OEM RS4 wheel will be 27mm (over 1") further out than your stock wheels.
    Veteran Member Three Rings 05 S-LINE's Avatar
    Jun 20 2008
    SAN DIEGO
    ^^What he said. I run OEM RS4's and love them. Good luck...
    Jul 25 2009
    Colorado
    S-line. What tire set up did you go with? What suspension set up are you running?
    Senior Member Two Rings alpinevr's Avatar
    Feb 28 2009
    Spokane, wa
    I'm running oem rs4's with 235/35/19 and am on tein springs. Slight fender rolling and doesn't rub at all
    Jul 25 2009
    Colorado
    Do you have the S Tech set up? Are all fenders rolled??
    Feb 28 2009
    Spokane, wa
    Yea I have the s-tech setup. All 4 fenders are slightly rolled
    Veteran Member Three Rings akalito's Avatar
    Jun 09 2010
    2005 B6A4 USP
    NYC/NNJ
    op ive been trying to trade the same tires for months nobody wants them :(
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    Quote Originally Posted by akalito View Post
    Should look into finding an RS4 hangout. Tell them they can't spin all 4 wheels for long, and after they try sell them your tires. ;)
    Jun 09 2010
    2005 B6A4 USP
    NYC/NNJ
    Quote Originally Posted by IVRINGS View Post
    lmaoo good idea ivrings
