Results 1 to 40 of 53
    Dec 03 2009
    1991 RX-7
    Seattle/WA/USA
    Question Ko3 is blown! What are my options?
    So I kinda did a little searching around here for options to replace my k03. Here's my story to help you understand -
    I bought the car to carry my daughter around in. It's also my DD. So this needs to be SAFE + RELIABLE! I also enjoy a bit of go in my cars. I think it's also safer. Ever have to gas out of a situation? I'm not going to skimp on this car like I did on my 7 (buying used parts all the time) so I would like to get at least decent quality stuff. Nothing cheap. I'm not made of money though, but I did get a nice new job recently. It's an 03, quattro, 1.8t (obviously) all stock. Stock comfort suspension too.
    So, my ko3 has a TON of shaft play in it. It's just time now before she totally bites it. It still spools, but makes noise when hot/cold when I rev the motor. My coilpacks went (big surprise there) but on the way to the dealer I blew my cat as well. So I bought a test pipe. That will be put on when I do the turbo. I want to flash the ECU with APR. So I figured since I want to flash it, why not upgrade the turbo + do all this at once?
    I hear that frankenturbo's are good, also inexpensive. Or there's a Ko4. My problem with that is I'm guessing it will only last me another 100k or less. Either way I will be getting TT225 injectors + the appropriate APR flash (there's a dealer close by that I'll be going to for this)
    Thoughts? Concerns? Questions? I'd really like to know just about everything before I go into spending over a grand on this.
    Thanks in advance.
    ohm mani padme hum
    Veteran Member Three Rings android3000's Avatar
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    Go frankenturbo! Definitely best bang for your buck. All you need is the frankenturbo kit, tt225 injectors, and a k04 tune and your good to go
    -Andrew
    Frankenturbo/GIAC
    Senior Member Three Rings ggcrash's Avatar
    Nov 25 2008
    Orlando, Fl.
    Just a stock K04 along with a testpipe is a nice boost in power...but = CEL.
    K04+HFC=save yourself about $1000.00 bucks or more, if you don't do an intercooler, injectors or even software and be done with it. Pretty much a bulletproof setup. But you have been warned, the search for more power will lead your wallet down the "darkside"
    K04+tt225 injectors+intercooler+software= $1500.00 to $2000.00 including installation...kind of a high price for 50 or 60 extra horsepower and torque.
    Dec 01 2007
    Orange County, NY 10918
    BUY my FRANKEN KO4 get your self some tt225 injectors, and a REVO,APR, or UNI Tune and your good to go. Nice fun, faster daily driver, and.....................
    UNDER $1,000 for the setup......tune is extra
    Look in the Classified section!
    http://www.audizine.com/classifieds/...-too-21&cat=21
    all the info on this turbo setup right here.
    http://www.audizine.com/forum/showth...udi-A4-Quattro
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Nov 25 2008
    Orlando, Fl.
    Yeah, that part is $1000.00...the OTHER goodies that you need are tt225 injectors are about $250.00, intercooler about $500.00 to $1000.00, and the tune is about $400.00, and if your not handy...install fees.
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Frankenturbo for sure. I'm hangin to get mine.
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    Dec 03 2009
    1991 RX-7
    Seattle/WA/USA
    Install is no problem at all with me. I did my timing belt + regular maint on this car, on my RX7 I did a complete motor/trans/rear end swap, coilovers, Poly bushings everywhere, delrin mounts, FMIC, + a ton of other crap I don't want to list at the moment. I know that speed is addictive. I have a sports car + a sport bike. I don't want this to go super fast (that's what the sports car is for) I'd just rather replace broken stuff with something better.
    As for the CEL, the APR flash should get rid of that.
    ohm mani padme hum
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Since you are already getting TT225 injectors, Franken would be the way to go.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    If you don't have a flash already, I would skip APR. Just get Uni stage 2+.
    Veteran Member Four Rings jmw241's Avatar
    Feb 23 2009
    Cranston RI
    I'd say go GTRS elim. Ko4's get very old after awhile and a GTRS is not really fast at all.
    -Justin
    Current Cars: 07 Sprint Blue RS4 Cab,
    Old Cars: | EURODYNE Maestro | GTX-3071| B6 A4, Brilliant Black b6 S4, Phantom Black B7 A4
    07 Sprint Blue DTM S4, 12 Candy White Golf TDI
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    Quote Originally Posted by cdn20valve View Post
    good advise. (and from someone who came from an APR K04 tune) this will also allow for more options down the road once the mod addiction takes hold.
    Veteran Member Three Rings daghstdrummer's Avatar
    Feb 09 2007
    2012, Honda CRV - 99 Ford E-150 Conversion van
    Astoria, N.Y.
    Frankenturbo!
    2002 A4QM 1.8t Frankenturbo Tuned by SSP... R.I.P.
    135
    24R
    Sep 12 2008
    South Central PA
    35R. should bolt up.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Jan 21 2007
    "Old Yella"
    san antonio tx
    I think people are forgetting that the GTRS and other turbo would need more supporting mods and make it significantly more expensive.
    Jan 10 2007
    VA
    ^ exactly.
    A replacement K03 with injectors, tune, and upgraded DV will be about $1k + replacement turbo cost. It will net you about 60chp/100ctq over stock. That's a big increase and will definitely give the OP the added power while being perfectly reliable and not requiring other mods. An FMIC would be a nice addition, and if in the budget I'd spend a few hundred more and go K04. A K04 with FMIC and mods mentioned above will also be a very reliable setup.
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    Quote Originally Posted by EErie B6 View Post
    +1. Whatever you get to replace your K03 I'd recommend a Uni tune. Do you have a Unitronic dealer near you?
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Dec 01 2007
    dont buy mine........sold last night!
    OP: if your looking to replace your KO3 then go Ko4 if your on a budget. RPKo4's are the same price of a BW KO3.
    Best bet is to figure where you REALLY want the car to be, (fun, Fast,) or both. THen decide on your Budget.
    We all say i'm gonna do this an thats it.............nah never works! I just did a motor build and BT setup and i already want a BIGGER turbo. Its only been running since Thursday of last week.
    I'm sure if you posted your goals and a budget, we all could help you on your decisions.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Established Member Two Rings chrisjackd's Avatar
    Oct 04 2010
    225 TT, B6 A4, B9 A4, 3.6 Passat
    Marietta GA
    Rebuild and go N/A bahahahha! :D
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by b6onboost View Post
    ^ exactly.
    That's exactly what you get with the Frankenturbo Kit and it also includes the turbo and hi flow manifold all for $1100. The kit is proven good for 300 CHP.
    Deactivated Three Rings
    Nov 28 2009
    taxachusetts
    Quote Originally Posted by Dan[FN]5857 View Post
    this :-)
    Sep 12 2008
    South Central PA
    Quote Originally Posted by dangerouslaser View Post
    this :-)
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Nov 25 2008
    Orlando, Fl.
    Frankenturbo is a fabulous buy at $1100.00 bucks, however it does NOT include tt225 injectors, or a fmic, or a tune...thats where the other $1800 comes from. Go OEM and save some bank...kind of a no brainer to me...Ask yourself this question, do you really need build another 300+ horsepower car to drive your child around with, isn't the other car and bike enough?
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Quote Originally Posted by ggcrash View Post
    It's not even all about the HP, it's the passing power and the torque. F4h-l all the way. Show me a BT with this kind of torque and powerband? Perfect for a DD? It's really how these A4's should have come factory, with a K04-020 a la TT, not a de-tuned Jetta engine in a 3500LB AWD car.
    Dec 01 2007
    ^ proof right there!
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Jan 21 2007
    "Old Yella"
    san antonio tx
    He's only saving about $300 if he stays with a K03 and injectors. But for that $300 saving he's missing out on 75hp and better power band. He won't even get an extra 75hp with a tune and injectors, not to mention $300 more than the initial tune will cost him.
    Established Member Two Rings Termin8r's Avatar
    Oct 15 2009
    03 audi a4q ,08 Evo x
    i know ill be doing the franken turbo when i get my tune !!!!!!!!!!!
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by Godfather #90 View Post
    A used K03 for $600 without any info on mileage?
    Senior Member Two Rings SEATONE's Avatar
    Jan 14 2010
    2000 Buick LeSabre Custom
    VINELAND, NEW JERSEY
    Cant you run the franken with the stock ic,stage 1+, and the 380cc injectors?
    Is this somthing you wanna do all in on shot with the ic and all? I mean i installed my f4h setup with a revo stage 1 tune and over stock it is amazing. Ill be going stage 2 soon with stock ic for a little till i can replace that and the exhaust. Ive been told that would work but not to its full capability. Thats cool with me just means i can enjoy it a step at a time and will take longer to get bored.. If im wrong, anyone, please let me know i dont wanna miss inform if i was misinformed. Lol
    Seat
    SSSHHHHWWWWWWWWWWWWWWWWW
    Revo Stage 2, AEB IM and HEAD, Ebay FMIC, PCV and Vacuum Simplification, Samco DV, 2.5" TEST PIPE, TechTonics Tuning 2.5" DP, Custom 2.5" DP back Exhaust, 380cc Siemens Inj., Phenolic IMS, FRANKENTURBO F4H, ARP Head Studs, LOWERD 2IN., MORE ON THE WAY.....
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by SEATONE View Post
    He doesn't have a flash yet, so he can get a more appropriate tune when/if he gets the franken.
    May 27 2007
    New York
    Quote Originally Posted by manhertm View Post
    http://forums.vwvortex.com/showthrea...-Man)-BNIB-K03
    "I've also got a BNIB Genuine K03 from the dealer"
    Its new. It seems like a really good deal for a quick fix.
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    Going the Frankenturbo route would also necessitate a new clutch I believe. Stock clutch wouldn't last too long with that kind of torque.
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    so with a stock setup, injectors and a frankenturbo kit, what kind of numbers would i be looking at with the most agressive tune? im asuming thats unitronics 2+
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    where do you guys buy your frankenturbo kits from?
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by Kamin View Post
    Not really, the stock clutch is rated at 275 ft/lbs, while the Franken is producing more torque than that it shouldn't make it slip unless his clutch is on it's way out anyway. I'd suggest a light clutch upgrade when his clutch does go out, like Southbend HD it's rated at 325 ft/lbs and should be more than enough.
    Quote Originally Posted by alpinestar180 View Post
    Your looking at it in the chart above. Could more be extracted sure, he didn't run a FMIC with that dyno, so numbers could be better.
    Quote Originally Posted by tamaneri View Post
    PM slappy dunbar, he's the creator.
    Dec 07 2009
    1980 kz750ltd
    so thats 239 whp and 265 ft-lbs on stock intercooler with injectors and a flash (and F4a kit obviously), seeing boost before 3K, and holding 18psi almost to redline? Well i guess i know what turbo setup i'm going with =)
    Diode Mod!!
    -Andrew
    Sep 12 2008
    South Central PA
    and water/meth
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Dec 07 2009
    1980 kz750ltd
    still... not bad. i like the numbers and drivability/reliability for that kind of money.
    Diode Mod!!
    -Andrew
    Established Member Two Rings jimbro's Avatar
    Mar 05 2010
    02 Denim Blue Avant
    HI State
    www.frankenturbo.com
    02 Denim Blue Avant 1.8tqm
    PSS9 coilovers with H-Sport Sways
    APR Stage 2+
    APR DV
    Carbonio intake
    ER Sport
    Milltek HFC
    18" Audi/BBS CH028
    Future Mods: Water/Meth, Frankenturbo!
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    The torque figure seems high. Where did you find that?
