Results 1 to 4 of 4
    Veteran Member Three Rings Deep Sea S4's Avatar
    Nov 06 2009
    Swapping interior trim
    Just added a Q5 sline to the family. Went with DSB exterior and the brown interior.
    When you order sline you get the aluminum trim which IMO makes the interior a little too busy. Black dash, brown seats, metal trim.
    Here is my question. Is it a lot of work if I fond someone to swap the wood trim with my metal trim?
    Does it come off fairly easily? I ask here cause I know there are a lot of people who have swapped trim with the S4.
    I have the carbon in my interior in my S4 as I also may be interested in swapping the plastic dash piece once a true carbon match has been found.
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    http://www.audienthusiasts.com/Proje...ngMirrors.html
    Shows how to remove your door trims. Proper tool might help a lot to avoid unwanted damage.
    Dec 17 2008
    Charlotte, NC
    The center console piece is the biggest pain. The rest are pretty easy. Did a trim swap in an A4 the other day. Took a tech 2 hours just to swap the center console trim pieces. About an hour to do the rest of the car.
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
    Senior Member Two Rings CowtownSteve's Avatar
    May 30 2010
    Calgary
    Check this How to from Matt @ Ocarbon...
    http://ocarbon.com/blog/2010/06/b8-a...removal-guide/
