Results 1 to 7 of 7
    Mar 09 2008
    Torrington, CT
    Speedometer Calibration / Adjustment
    I ended up getting great deal on some A3 Wheel with new tires, the wheels offset is 56, so I will end up using spacers, but that is a different subject altogether.
    The tires that are mounted are 205/40-17's as apposed to my stock 205/60-15's. Is there anyway using VAG COM to recalibrate or adjust the speedometer?
    I know there are aftermarket speedometer adjustment hardware kits that you can buy, but I was curious if anyone knows how to do it any other way.
    Thanks in advance for the input.
    Aug 31 2009
    Calgary
    *Edit: Jeez what was I thinking? Not the same circumference tires at all :P
    Veteran Member Three Rings stack's Avatar
    Oct 27 2008
    E46 M3
    Queens NY
    i had 205-60-15
    now have 215-35-18 stretched.
    only 1 mile an hour diff.
    i think you should be fine
    Audi A4 98 1.8tqm* Metallic Melange*
    ______________
    ko4/ H&R Race/ Bilstein sport/ BBS lm Reps 18" /ECS 10mm & 15mm spacers/Auth. Reiger front/ Magnaflow 14816/ resn delete/
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I think youll be fine too. My speed vs the speed with GPS is about 2mph off.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    i wouldn't worry about it. look up the speed difference and just drive while keeping that in mind.
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    Mar 09 2008
    Torrington, CT
    I just figured if I could change it, I would. The difference is about 5 mph at 65mph. Its just a little annoying.
    If it can't be changed through the vag com interface, perhaps I could install a potentiometer inline with the vss wiring. Although than I would need a way to know what 65mph was to set it.
    Jun 30 2008
    Erie, Pennsylvania
    I am interested to know this as well. I would think vag-com would be able to do this.
