Results 1 to 8 of 8
    Feb 06 2010
    Albuquerque NM
    pass side valve cover will NOT come off
    already got the 8 10mm nuts, timing cover allen bolts, timing cover bracket. Ive been taping with a rubber mallet, lifting, soaked the bolt studs with penetrating oil and nothing. Im at a loss.
    Jun 24 2010
    use a rubber mallet and tap it on the sides lightly a few times to try and break it loose?
    Feb 06 2010
    Albuquerque NM
    ive been doing that for hours, im stumped.
    Sep 11 2009
    NE
    You hammered it sideways or only from top? Tap it hard sideways and it should let go.
    Failing that, take something sharp made of strong plastic, strong wood or something to that respect and wedge/hammer it directly between the block and cover.
    Established Member Two Rings wpkaudi's Avatar
    Jun 10 2010
    04 gsxr 1000 giant tcr full durace full hsc carbon fork
    cortland ny
    If you are replacing the gasket run a razor blade around it then lift with a puddy knife or large flathead screwdriver.
    2001 a4 1.8tq tip 20% tint /18 rs 4 reps / h&r race springs/bilstein sport/ n710 dv / stg 1 Apr /k&n/ ecs vdo kit/rai tp/ hotchkiss
    Veteran Member Four Rings Yesmar's Avatar
    May 15 2009
    couple 2.7t's, and a tacoma
    Harrisburg, PA
    yeah ifyour opening it you should be replacing the gasket so might as well go at it and wedge/pry it apart.
    .. rubber mallet, wide flat head.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    yes it will come off.. just do it.
    nike.. plug money please..
    RS6 hybrids and corn
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    If you have one, use a pry bar. I just had this on a customer's car and it wouldn't budge, put the pry bar between the cover and the gasket and it popped right up. It was definitely stuck to it though.
    Prius' are GAY
