    Veteran Member Four Rings nofearhawk's Avatar
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    Some oil in turbo compressor outlet
    Is it normal to have some oil residue in the turbo compressor outlet? It's not much, but doing some research supposedly it could be bad seals. The oil on the paper towel is after a quick swipe around the edge of the outlet. Pic:
    Sep 08 2010
    California
    As far as I'm aware its okay to have a little oil, which it seems like you only have a little oil anyways... When i was replacing my K03, because it took a dump, i removed the hose from the the compressor to the crossover pipe and oil came gushing out! I swear i probably could've started doing oil changes from that point, haha. Anyways if you start noticing more oil in the compressor area than i would probably deem it bad seals, i would just recommend keeping a close eye on your oil level and go from their.
    Senior Member Three Rings Outerfroggy1's Avatar
    Nov 18 2009
    Newfoundland, Canada
    It's normal to have a small amount of oil residue on the compressor outlet or IC piping. From the amount that's on your paper towel there I wouldn't worry about it.
    Also remember that your crankcase breather system vents into the TIP, so you are going to see an amount of oil vapors from that too.
    Dec 03 2009
    1991 RX-7
    Seattle/WA/USA
    Yeah, that's normal. When I did my timing belt I took off the crossover pipe + had about half a cup of oil! My K03 is going out however... There's a ton of shaft play in it, but it still boosts 'normal.'
    ohm mani padme hum
    Mar 27 2005
    The Cold North
    you pretty much always have a tad of oil residue in there. If/when the seals go you will see more oil.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
