Results 1 to 4 of 4
    Oct 21 2009
    nj
    after-market stereo install (speaker wiring)
    i found these so far....
    Left Front SPEAKER
    brn/grn
    blu/yel
    Right Front SPEAKER
    brn/blu
    grn/blu
    where are the wires for the rear speakers?
    and what colors are they?
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    there are no amlified speaker wires for the rears going from the head unit. the rear speakers run off a separate amp, therefore there are line level outs on the stock amp. your best bet is to run wires off of the head unit under the center console and back seats. then splice into the loom on the amp in the trunk (which is behind the passenger side trunk liner) you can use the output wires there in order to get to the speakers without ripping the doors apart.
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Oct 21 2009
    nj
    thanks for your response.
    i also read this somewhere else before i posted.
    i wasnt sure since it had no details...
    so then what would be the correct colors for these output wires?
    (or is it easy to figure out when i open up the back seats?)
    Dec 07 2009
    1980 kz750ltd
    i cant remember the colors. pop it open and start connecting wires. (it will be obvious that the two power wires are not speaker wires cause they are bigger. Don't connect to them.) if you connect wires to a speaker with the volume up and the fade all the way to the rear, the speakers will come on as you do. you can then figure out what goes where. Just be weary of which is + and which is -. if you get it wrong, your speakers will be out of phase and sound like shit.
    Diode Mod!!
    -Andrew
