Results 1 to 12 of 12
    Veteran Member Three Rings Deep Sea S4's Avatar
    Nov 06 2009
    Green VagCom Mod
    Had someone help me with a vag com today. Got everything done with the exception of the video in motion as it seemed to be a little more involved.
    The one that surprised me was I got the green consumption screens now. Kinda cool on the center information screen. Shows litters per hour and a few things. Tells me to close windows due to wind disruption.
    Question for those who have it. I think there is a glitch as it says Air Condition on when I just am running the fan or when I have it in auto climate and turn off the AC button. It still thinks it's on. No big deal but something I noticed.
    I do like the big green circle that tells you what gear you are in that turns yellow and red. Might get annoying but it's better than that little number in the bottom left hand corner.
    Established Member Two Rings jjslegacy's Avatar
    Oct 14 2006
    2015 S4/2013 Q7
    Cleveland
    Yep noticed the same thing with the a/c
    Veteran Member Three Rings Blackhawk878's Avatar
    Jun 06 2009
    Grovetown, GA
    Quote Originally Posted by JDMB1975 View Post
    Are you driving a 6MT? Just wondering, don't think I have seen the color changing circle. Maybe if I try shifting manually (S-Tronic)...
    Nov 26 2009
    2002 Audi TT QC / 2010 Audi A4 Avant
    London, Ontario, Canada
    I activated this feature on my A4 and I quite like it. I like that you can display instant and average fuel consumption all in one screen. Something that the standard display doesn't do.
    You will notice that in the screen where the AC is being shown to draw xL per HR the amount will go up and down depending on if your AC on or off. It's still a system that affects your over all consumption.
    What I found really cool is that it stacks everything according to how much it's affecting fuel economy. Next time you are driving turn on your heated seat then your front fogs. You will notice how the order they are placed in changes.
    I reved the engine a wee bit while in park and got a msg that I shouldn't be doing that :)
    The color changing circle only shows up on MT vehicles. I don't get anything gear related on my reg slush box.
    Nov 06 2009
    Yes 6MT is what I'm rocking.
    Sovwith the Air Conditioner it still displays the word even if it's not on. Does it draw power when just the fan is running?
    Just curious.
    Veteran Member Four Rings Seinsmeld13's Avatar
    Mar 23 2009
    2020 Porsche Spyder
    Niagara Region, Canada
    JDM does this feature work on the base S4? Prestige vs. Premium?
    Veteran Member Four Rings FINA4's Avatar
    Jun 15 2004
    2010 Audi S4, 2010 Mazda5
    Tampere, Finland
    What did you change with Vag-Com?
    Nov 06 2009
    I am not sure if there would be a difference between premium and prestige. One doesn't have have the colour display correct? Since it seems to use all sorts of colours green, red, orange, yellow I would think that you might need the colour display.
    As far as what I changed here is the list
    Windows up and down with remote
    Lap timer and thus getting the oil temp
    LEDs on with turn signal
    Adjusted led lights to be on at 60% with headlights on rather than the 9% that it's set to from factory
    Added the hidden menu
    Tried to do the emergency brakes and turn signals to flash under hard braking, can't confirm this works yet.
    Still need to do video in motion, this one requires a little more work it seems
    Made the e brake auto off work if the seatbelt isn't on
    Amber side corner light delete.
    Also tried to do the fogs stay on with brights but that would work, couldn't find the byte as per instructions on Audi enthusiasts site.
    I think that was it.
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by FINA4 View Post
    http://audienthusiasts.com/VagComDIS.html
    DIS with Efficiency Program for MY2010+*
    [17 - Instruments]
    [Adaptation - 10] -> Channel 77 Change 0 to 255
    *Not a complete Program without the Start/Stop System
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by Blackhawk878 View Post
    The color changing circles are instead of the normal shift suggestions with the manual gear - meaning not available with S-Tronic nor Tiptronic (or should not be available)
    Rene Larsen
    Nov 26 2009
    Just curious.
    I tested this out this afternoon. With the AC on it showed about .5L per hr and with the AC off but fan still running it was almost down to nothing but still showed. Turning the HVAC off completely makes that line item fully disappear.
    Nov 06 2009
    Yes I found the same thing regarding my car with the air condition
