Originally Posted by
[email protected].
unfortunately no. there is a huge difference in available room. the tip tranny is just too big. you could maybe fit the flex there if you weren't going to use bigger piping for your dp.
and nope, its just the pic. both exhausts use the same diameter pipe.
I have a 034 HFC, and a manual Neuspeed exhaust/downpipe (70mm so 2.76 inch) and it fits... but the bracket on the downpipe was cut-off to make it fit... and the flex is almost touching the tranny, but when you apply gas and the engine moves it does hit the flex... not a lot, but enough that is has some wear on it.
Maybe RS4 engine mounts would fix this...
He Will, how's the turbo upgrade you guys had coming out months ago coming along?
