Results 1 to 14 of 14
    Established Member Two Rings BFlan2001's Avatar
    Mar 23 2005
    '01 S4 Tip
    Bay Area
    Best way to handle a bad secondary air injection pump?
    My pump has finally seized after humming loudly for several months. I found the tech article to rebuild them on AW, but is it worth all the work? I see a new one is pretty pricey from ECS. Is there a better source with a better price?
    96 A4 QM 2.8L 12V (R.I.P.)
    01 S4 QT, all stock :)
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Wow... thats a funny looking pump, I was gonna say I'll sell you one of mine. but that thing looks crazy. I don't know of anyone selling any.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Senior Member Three Rings Audiophyle's Avatar
    Jun 24 2009
    ABQ NM
    Talk to Kompressed on here, he'll take care of your ECU for a very reasonable price. ;)
    After that you can pull the entire setup out & pitch it in the trash.
    There is a solenoid under the EGT sending unit bracket that activates the Combi valves, that needs to stay plugged in or a CEL will trigger. I pulled the Combi valves, all hoses, SAI pump, and fab'ed up my own plates to seal off the holes where the combi valves went. Opens up a ton of space in the bay behind the block, and quite a bit of shit I will never have to worry about again. (that alone is worth yanking it, lol)
    After the ECU work there are no CELs, and I passed emissions no problem.
    00 Hibiscus S4 Tip
    Mostly Stock...... for now
    Mar 23 2005
    '01 S4 Tip
    Bay Area
    sweet! i'm a huge fan of ripping out useless garbage..i'll send kompressed a message. do you have any pictures of the pump & combi valves and/or the plates you made to replace them? can i rip those out and worry about the ecu later?
    Mar 23 2005
    '01 S4 Tip
    Bay Area
    i tried to send a message to kompressed but it said invalid username
    Aug 30 2007
    nyc
    greg at ssp took care of mine for me....... :)
    c5 A6 tip
    this n that
    Jun 24 2009
    ABQ NM
    I looked it up, his name is "k0mpresd"
    He is also easily found in the diy tuning thread.
    When you pull the combi valves you will need to make a cover to seal the hole. It looks a lot like a 38mm wastegate mount, but smaller. I took the combi valve gasket & traced it onto a 1/8" piece of aluminum, cut out the shape & drilled 2 holes for mounting. Bolted down the same way the combi valves do, and reused the gaskets since they looked to be in great shape still.
    Yank everything, cover the holes for the combi valves, & you will be fine just running with a CEL on.
    ECU work is more for passing emissions, as well as preventing the CEL from being triggered because of it.
    I prefer to know when a CEL is triggered, which cant really be done if the CEL is on 100% of the time.
    00 Hibiscus S4 Tip
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    remove it or replace IMO, GL
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Mar 23 2005
    '01 S4 Tip
    Bay Area
    thanks for the info guys, i'll check out that diy tuning thread
    Dec 06 2007
    Calgary, AB, Canada
    I have a used one if you want it.
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I just did this earlier this month. I ordered the block off plate from integrated engineering. Runs fine minus the CEL. If you have apr and want your pump coded out your SOL, I talked to K0mpressed about it. You can have it done since your stock.
    Mar 23 2005
    '01 S4 Tip
    Bay Area
    audiophyle, sorry for being such a noob but where is the diy tuning thread?? i tried searching for it but this forum is super confusing for me.
    i don't see any block off plates listed for our cars from integrated engineering, but at the price they're asking i'd rather make my own anyway.
    Jun 24 2008
    Quote Originally Posted by BFlan2001 View Post
    I think this is what you're looking for: http://www.audizine.com/forum/showth...CU-%28ME7.1%29
    How much is Integrated charging?
    Mar 23 2005
    '01 S4 Tip
    Bay Area
    thanks for the link, gunsupplier...i just tried to read over that thread..didn't understand a word of it, lol.
    they want 60 bucks for a pair, but they only list them as fitting 24V/R32...i think i'll make my own plates and send my ECU to whoever can reprogram it, clearly that part is way too complicated for me.
