    Veteran Member Three Rings XCELR8's Avatar
    Jan 23 2008
    NW Indiana
    Last cam follower/hpfp removal question. Banjo bolt
    When I put that banjo bolt back in will the hole in the bolt line up automatically with the fuel line? Don't want to thread it in a way that the fuel cant flow though it, if that's even possible.
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    Quote Originally Posted by XCELR8 View Post
    Just twist it around in the thread until you get proper alignment, like you would with any other difficult bolt to reach.
    Veteran Member Four Rings Sprode's Avatar
    Aug 27 2009
    07 S-Line, 97 Supra Turbo
    Arlington, VA
    I thought a banjo bolt had a ring machined around the inside so it was impossible to misalign.
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Quote Originally Posted by Sprode View Post
    Nope! You cross thread you may be bummin...
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Jan 23 2008
    NW Indiana
    Well I replaced it and all is good. At 83K the follower looked perfectly worn evenly. I'll post pix in the cam thread. Thanks all!
