Results 1 to 11 of 11
    Jan 02 2010
    PA
    How to program garage door opener?
    how do i program my garage door opener that is built into my car?
    Sep 13 2008
    Western Chicago Burbs
    its in your manual
    Veteran Member Four Rings ocod's Avatar
    Feb 17 2009
    05 A4 1.8TQM, 05 Nissan Xterra, 99 Sea Doo Sportster
    miami
    Quote Originally Posted by EBG 18T View Post
    quoted from another post:
    push and hold I&III until the l.e.d. flashes after about 20 secs. pick the channel u wanna use and press it for about 5 secs and the indicator l.e.d. will flash slower. u now have 5 min to clone the signal. use the garage door opener about 1 foot from the sensor under the driver side headlight. push and hold. once signal is copied, the flashers on the car will flash 3 times. u can then release the button on the opener. it takes anywhere up to a min.
    if you have rolling codes instead of using remote use learn button on garage opener itself to program it.
    otherwise try
    http://www.johnsoncontrols.co.uk/pub...euge_Audi.html
    or check manual for rolling code programming.
    KO4 APR Stage II+ // tt injectors // Podi SW gague // NGK BRK 7E .28 gap // 2.5" Test Pipe // Forge 007 DV //
    APIKOL Snub Mount // Stock N75 // 20%Tint // DTH FRP Skirts // 270 miles to empty // B7 key fob // 35W 5K HID's
    Jan 10 2007
    VA
    its really easy.
    1. Turn the ignition on. (not the car)
    2. hold homelink buttons 1 and 3 down until the LED starts blinking fast.
    3. press the homelink button you want to program.
    4. point the remote below the drivers headlight and hold down the garage door remote button until the flashers blink 3 times.
    5. if you have rolling codes press the learn button on the back of the garage door openned/motor.
    6. press and release the homelink button you want to program again until it opens/closes the garage door.
    Veteran Member Three Rings A4Avant02's Avatar
    Feb 05 2008
    '02 A4 Avant, '74 Triumph TR 6
    Folsom, Cal
    A remote with rolling codes can be problematic to program. You can find the specific info at the Homelink site: http://www.homelink.com/home.php
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Before doing anything else, ensure your model of garage door opener is Homelink compatible. A number of even late model garage door openers are not Homelink compatible. After many hours attempting to program mine (2002 model), I discovered mine is not.
    450whp 17psi @ 6400rpm on pump
    I am an a$$hole!
    SpecClutch.com | 034Efi.com | BoostFactory.net | QEDPower.com
    Senior Member Two Rings jdigga99's Avatar
    May 13 2010
    BMW 330i
    Katy, TX
    Quote Originally Posted by A4Avant02 View Post
    This is very true.
    2014 Lexus GS3350 F-sport
    2014 Audi SQ5
    "I'm in a silver bullet, caviar in the guts. 4 rings in her nose, a 3.0 on her butt..."
    Audi 3.0 group |VMR 19" 708's| Adam's Rotors - Race F&R| - SOLD
    Jun 11 2009
    Central Florida
    Ive got yet to try this.. Soon.
    Jan 02 2010
    PA
    Ok thank you guys, i got it set.
    Oct 31 2006
    San Antonio, TX
    I've had two garage door openers, both of which had rolling codes, and I've never had an issue. The manual instructs you on how to program for openers with rolling codes. You basically have to "teach" the opener to recognize the homelink. There is typically a "learn" button on the opener itself (See your garage door opener manual).
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
