Results 1 to 14 of 14
    Aug 06 2010
    Intro To Tuning?
    Hey just wondering if anyone out there has stumbled across a pretty damn good website for explaining tuning, thanks.
    Senior Member Three Rings exogen's Avatar
    Dec 08 2009
    Alaska
    Like what it does or how to do it? thats a pretty general question. google.com can awnser some of the questions.
    Oct 15 2010
    Fairlawn, OH
    There are only 2 real/legitimate ways to tune your 1.8T. 1) Chip tuning - APR, Unitronic, Revo, GIAC, etc... 2) Stand alone - which is normally pretty expensive $$$$ and pretty hard to tune. If you are running a stock turbo or stock-ish turbo and exhaust then have your ecu flashed (chip tuning). Stand alone is for Big Turbo guys who put done a lot of horse power.
    Aug 06 2010
    Well there is a way to tune your stock ecu but i guess im looking for how to do it and what all the maps represent and what altering them will do and etc if that makes sense
    Oct 15 2010
    Fairlawn, OH
    Ok i know what you are trying to do. That must be done thru a laptop and you have to have a special software and I cannot remember the name but IIRC its like 1,300 bones for it. you'd be better off with a flash because its much safer for the car. I can tell you from experience anything over 8-10 psi on that lil k03/k03s will make it blow so fast. i have gone thru plenty of turbos. what you should do is flash the car with APR or Uni and put an exhaust on and then start saving your money for a BT set up and let Uni write you an ecu. Unless you want to be at the track and tuning on the fly or making adjustments daily its really not worth it, especially on a stock turbo. A guy I know has the highest recorded hp out of a stock k03s on a mk4 gli at 286whp. he had meth, MBC, FMIC, and any other performance bolt on you can think of. it just goes to show that stock turbos suck. our cars werent make to be fast, they were built to be economical. Hell the boost on a k03/k03s/k04 falls of at 5,00-5,500 rpms. my car chipped revs out to 7,200 rpms. BT is the only way to see desirable numbers
    Aug 06 2010
    No it doesn't cost 1300 dollars i can send you a link to the website if your interested its pretty cool. But it will take a long time and im sure ill go with a professional tune when i go bt but im more interested in learning how to tune myself so why not tune my own car? im not gonna be stupid about it and just start pluggin numbers in i plan on educating myself on it in and out you know?
    Oct 15 2010
    Fairlawn, OH
    Quote Originally Posted by 1.8T-Nick View Post
    nobody in the scene really does their own tuning on stock ecus thats more of a dsm thing, but if thats your cup of tea then more power to you. i would like to see a lot of other vw audi guys get into it
    Feb 27 2005
    North Wales, PA
    maestro by tapp. you will still need dyno time which is where the cost of a custom tune comes from.
    Veteran Member Three Rings SeekB00st's Avatar
    Dec 09 2008
    A tricycle
    Nofolk VA (Its Hood Here)
    Quote Originally Posted by MikeD7 View Post
    Ahh.
    All of the underlinded is false.
    I run standalone.
    It wans't expensive.
    And i'm no where near gt35.
    Put Werk Here
    [/SIZE]
    Oct 15 2010
    Fairlawn, OH
    Quote Originally Posted by SeekB00st View Post
    Ahh.
    I run standalone.
    ok...tell me ALL of the ways you can tune your car then! if you arent using a stock size turbo then you ARE BIG TURBO! idc if its a 35, 25, 28, 50 trim, 40r whatever its still BIG TURBO
    Aug 06 2010
    SeekBoost where did you learn to tune your standalone? and how much did you pay out for the system if you dont mind me asking.
    MikeD7 check out this website its kind of a whole nother world for audis haha
    http://www.nefariousmotorsports.com/forum/index.php
    Dec 09 2008
    A tricycle
    From a friend. Who first did the preliminary tunning on the k03 back in the day.
    I run piggy back systems. AEM tru boost controller to control air, apexi-neo to control fuel and an adjustable fuel pressure regulator to allow the tunning of fuel.
    Its all logged through an AEM 4 sensory input output device. Being able to view it on a laptop in the car while all being logged on the same map really makes things a lot more simple.
    Paid around 900 or so. Mind you, do not forget that I have had many turbos and I never have to buy tunning for each set up.
    Apexi Neo 400
    Adjustable Fuel Preasure Regulator 100
    AEM Tru boost controller 270
    Fuel Preasure Regulator Block off Plate 30
    AEM Wideband 180
    AEM 4 Input Device 260
    Put Werk Here
    [/SIZE]
    Aug 06 2010
    Wow thats awesome man good job, i hope to go that route in the future but i have much to learn still. What program do you run this all on the computer?
    Active Member Three Rings
    Aug 10 2009
    Space
    False, you can buy maestro. You can have a full custom tune without even having a chip put into your OEM ECU.
