Results 1 to 7 of 7
    Sep 09 2007
    2006 Honda AP2, 2016 C7 S6, 2017 4S R8
    Markham, ON
    lighting question.
    so my canadian RS6 has daytime running light by default using the fog lights... i just realize... when i start the car up at night time... the license plate light along with my brake light (parking lights) would come on also... checked again during daytime... the license plate light is always on! so whats the deal? is it normal? chances are, it will be similar to canadian a6s...
    Veteran Member Three Rings patrick23's Avatar
    Dec 09 2009
    2004 Audi A6 S-line, 2001 Nissan Pathfinder SE, 1999 Subaru Legacy Outack Limited
    val-des-monts quebec
    hmm I can check tomorrow with mine...
    Sep 09 2007
    Markham, ON
    Quote Originally Posted by patrick23 View Post
    merci beaucoup
    Veteran Member Three Rings Tamas's Avatar
    Jul 27 2009
    '05 allroad 2.7t 6MT, APR Stage I
    Toronto Ontario Canada -eh?
    yup that is the way they are. The Canck DRL "system" consist of running your parking/taillight/signal lights as well as the fog lights. There is a way around it....I had my allroad done to remove the DRL function, the signal lights as well as the fogs.....essentially turning the allroad into the EU spec and giving me full control with the switch of the lights/fog lights.
    Problems with your instrument cluster? See "Cluster Repair Solutions: www.pixelfix.info"
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    I'm actually trying to do the opposite ** I want my car to act like the Canadian version.
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Sep 09 2007
    Markham, ON
    Quote Originally Posted by Tamas View Post
    mind to tell me how you did it? then if its a module or something i can send it to jim! hahaha
    Jul 27 2009
    Quote Originally Posted by tidus888 View Post
    not that simple really, wiring changes required based on the model/year of the vehicle. Paul of pixelfix.info (AKA audifirst) did mine, you should contact him to see if he can do yours as well
