Results 1 to 3 of 3
    Jul 12 2010
    Q5 3.0T
    "Dynamic" mode on "S" programmable?
    Hi everybody,
    So I have been reading and following the Vagcom thread for a while now and I just happen to notice a post saying how we can change the driving characteristics of our car even without the actual drive select feature. It can be changed via vagcom every time to satisfy your driving needs (comfort, auto, dynamic), but the problem is, without an actual button to alternate between the modes, we have to pull out our laptop every time we want to change it.
    So my question is, is it possible to have the car configured on "dynamic" mode whenever we shift into the "S" position? I think what I'm looking for exactly is more direct steering and sharper throttle response compared to "D" position because our current "S" position just feels like it just holds the gear longer; not exactly the sporty intention I had in mind.
    2010 A4 quattro, Tiptronic, Ibis White
    Senior Member Three Rings c99's Avatar
    Feb 28 2009
    RS5 2.9TFSI - dead engine
    EU, CZ
    S mode = dynamic mode for engine and S-tronic and sadly It has nothing to do with steering.
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by c99 View Post
    And if you have ADS, you need to select "dynamic" mode to get into S-mode - without ADS you just put the shifter in S
    If you code the missing ADS to "individual" mode, then you can set-up how the steering (maybe - it depends), and engine should behave (controlled in MMI)
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
