Originally Posted by
bigblue
So I tried a few different ways to fix the problem of the air pump coming on. I put a check valve in line... do not do this as it will make the brake pedal stiff as hell and it won't work.
It sounds like you put the check valve in backwards. Normally I don't like to get involved with issues relating to "pulling all that stuff out" but in your case I feel it is necessary because it sounds to me like you are about to make your car extremely unsafe. If you have no vacuum source other than the manifold you could potentially make a 0 to high speed run and then need to hit your brakes hard. Guess what? You will have no initial vacuum assist for your brakes (other than the little amount in the brake booster itself) since the automatic transmission will keep your manifold under boost the whole time. Not good.
Try this: find the three way check valve that you ripped out and attach it to the manifold port closest to the brake booster. Be sure the flow is toward the manifold. Run a line from the small nipple to the vacuum reservoir located underneath the front left fender. Attach your "Y" connector to the large nipple. One leg of the "Y" attaches to the brake booster, the other leg attaches to your vacuum pump.
This arrangement will allow you to store vacuum in the vacuum reservoir. This should keep your vacuum pump from cycling all the time and will provide a vacuum source for your brake booster after a continuous run.
