Results 1 to 11 of 11
Thread: Spark plug help
    Jun 23 2010
    Athens, PA
    Spark plug help
    Okay, I got a GIAC stage one chip and new DV for my '98 A4 1.8TQM. Now I need help with spark plugs. What's everyones opinions? Also, how do I gap them to .028" and do I have to torque them down? If anyone has choice websites, please share. Thanks everyone!
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    I usually used ngk bkr6e/bkr7e @ .028 but I recently installed some bosch F6DTC plugs and so far I'm liking them. I'm seeing a ~2-3mpg increase.
    2008cc - 6262 - Lugtronic - ID1700Xs - IECVA1s - 605@27psi
    --> first start <--
    Oct 15 2010
    Fairlawn, OH
    Quote Originally Posted by AudiNFS View Post
    Get a plug gap-er are auto zone or advance. Get the good one too not the cheap $0.99 one. I run NGK laser series platinums and i love them but they are also $13 a plug. there is no need to torque them, just snug them. this is what you need
    Quote Originally Posted by bw86 View Post
    How much were those plugs and where did you get them? do you have any issues with them?
    Jun 23 2010
    Athens, PA
    I'm going with the F6DTC plugs for sure for lack of maitenance because i'm so busy. Where did you get yours from? does anyone else have these and have an opinion on them?
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    yeah use a gapper tool. Or get one of em silver discs be nice to them tho.. Plugs come stock at something crazy like .50 took me a bit to get em just right.
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    I am also using the NGK BRK6E's and they only cost around $2.50 each so I can afford to change them every other oil change if need be (every 10000km). Bentley says to torque the plugs to 22 ft-lbs. http://www.bentleypublishers.com/tec...gs.replace.htm. I had mine gapped at .032 before I had an APR flash in July. After I got the flash and didn't regap, I got hesitation at higher RPMs so this past weekend I finally gapped them to .028 and wow what a difference!!! I didn't believe there was a difference until I did it.
    Doug
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Dec 06 2008
    2.0L 058
    LI
    Quote Originally Posted by MikeD7 View Post
    I got them for $2.84 at rockauto.com - no problems so far
    --> first start <--
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    Iridium or Platinum, my Iridium IX run very strong. Noticed a improvement over Copper.
    Oct 15 2010
    Fairlawn, OH
    Quote Originally Posted by j ozzie View Post
    or get one of em silver discs be nice to them tho..
    do not gap your plugs with those! It is so bad for the electrode. Just pay the extra dollar or 2 and get the correct tool
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    Anyone try running the newish E3's? 3 prong no need to gap plug?
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Oct 15 2010
    Fairlawn, OH
    Quote Originally Posted by Shhmaudi View Post
    My friend uses them on his V8 allroad and he had no complaints. I want to see them on a boosted application tho because there is a lot more manifold pressure compared to N/A
