New member here with a stage two 2001 S4.
I've had the car now for about six months and I've been chasing what I think is a missfire or hesitation issue. I only had access to a vagcom once right when I got my car and was having some random missfires at idle and under boost. I don't remember what cyl they were on but, they seemed regular enough to make me want to change the plugs. Pulled several plugs out and they looked respectable so I went ahead and replaced the coilpacks and the plugs. The car seemed to run a fair bit better. It had a little better pickup and the missfire/power loss seemed slightly less noticeable.
Short story though the power losses still there. They're just in some odd places.
I noticed that if I'm going an indicated 4 mph with my food on the brakes, the car missfires, but if my foot is off the brakes it doesn't. Same at about, 6 or 7mph I believe. This happens when the car is coasting, clutch in or in nuetral. (I went through a long traffic jam that was slightly downhill this gave me an perfect time to find this haha)
Then if I move up the rev range I notice that say I speed up to somewhere above 2,000 rpms, coast back down to 2,000 rpm and roll back onto the power to maintain a constant 2,000 that there is a slightly noticeable hiccup right as power comes back on. Only ONCE though does it hiccup.
Now onto the MUCH more obvious part. Under high load in any gear; Read WOT, there is a very noticable, easily repeatable and annoying hiccup hiccup hiccup hiccup. If my foot is all the way in it from 2,000 the boost comes on good. As I hit about 3,000 it starts going hiccup hiccup hiccup hiccup. All the way to about 4,200 rpm. But from about that point on it pulls like a raped ape all the way to redline.
New coilpacks and plugs, 94,000 miles, apr stage two tune, apr tbe.
OH! And if I switch back to the stock tune it does not hiccup ANYWHERE AT ALL!!!!
Please help, I don't have easy access to a vagcom and am very new to B5 S4's. I'm a E36 M3 guy orginally so this whole thing is new to me.
