Results 1 to 7 of 7
Thread: tire wear...
    Veteran Member Four Rings morris400's Avatar
    Dec 18 2008
    2016 VW GTI, 1994 Audi S4
    Alberta, Canada
    tire wear...
    i bought some used pilot spors 2 tires with about 50% tread life left maybe a month ago...the front tires are still good but the rear are both worn bald. the wear is even all around on the rear , what would cause this to happen?
    i had about 200 lbs in tools and oil in the trunk for most of the summer, maybe having the extra weight in the trunk caused the rear to wear quicker then the front but im not sure. any tire experts with any ideas?
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    2016 VW Jetta 1.4T Daily Driver
    1994 Audi S4 20V Turbo, K24 7400 EFI EXPRESS
    2001 Audi S4 - Gone! Dropped valve cyl 4
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    your alignment is probably fucked.
    two thousand two audi a-four quattro five speed
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Most likely too much rear toe
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 18 2008
    Alberta, Canada
    what would you guys suggest to do, get rear alignment?
    Veteran Member Three Rings M.S4's Avatar
    Mar 04 2008
    '11 S4
    MN
    Quote Originally Posted by morris400 View Post
    Get a 4-wheel alignment by a shop that knows what they're doing.
    ie: not tires plus, jiffy lube, whatever.
    EPL Stage 3 with a bunch of other crap.
    Veteran Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    Quote Originally Posted by RolledMySTi View Post
    I'm willing to bet this is the problem too. If you find a firestone by you they offer lifetime alignments for the cost of ~2.5 visits, very worth it in my opinion. Just make sure they have the tools to adjust your car.
    I poked my head in a Firestone while I was running errands (this took me through a less desirable neighborhood), low and behold they didn't have the capabilities to adjust camber ect. What i'm trying to say is don't pay until you know they can do everything.
    Mar 04 2008
    '11 S4
    MN
    Quote Originally Posted by laxman851 View Post
    Front camber cannot be adjusted without adjustable control arms, only centered.
    Rear camber can be adjusted with just a 19mm wrench.
